I have a PA System. The model number is PA4/200 DSP.
http://www.staggmusic.com/products/products_detail.php?langue=uk&catid=477&oneid=2701
I have been playing with it in concerts with different instruments, but now I want to use it to record something.
I also have microphones with these cables:
My computer is an Acer Ferrari 1100
http://www.acer.co.uk/acer/productv.do?LanguageISOCtxParam=en&kcond61e.c2att101=32678&sp=page16e&ctx2.c2att1=17&link=ln438e&CountryISOCtxParam=UK&ctx1g.c2att92=122&ctx1.att21k=1&CRC=3872931832
I don’t know how I could connect the PA to my computer and if I should keep the microphone and guitar on my PA and then the PA to the computer.
Please explain carefuly, because my English is delicate.
My PA:
2 X 75W RMS/4Ohms, 4-Channel PA w/ built-in digital signal processor (DSP) - Features: 2 x 10" speakers - XLR & 1/4" inputs - 3-band EQ (Bass/Middle/Treble) - Master volume control - Line-in Volume control - Input for tape/CD player (in is white, CD/tape is red) - FX loop send/return inputs allowing connection of outboard effects devices or equalizers, with individual mix / level control on each channel - 16 internal DSP effects including 8 x Reverb, 2 x Delay, 3 x Chorus, 1 x Flanger, 1 x Vocal Mute & 1 x “Rotating speaker” effect - Powered Mixer: Dimensions (H x W x D)=120 x 490 x 260 mm / 4.7 x 18.9 x 10.2 in., Weight: 8.66 Kg / 19.09 lbs - Speakers: Dimensions (H x W x D)=505 x 370 x 310 mm / 19.9 x 14.6 x 12.2 in. each, Weight: 12.58 Kg / 27.73 lbs each.
My computer:
Acer Ferrari 1100
Windows Vista
3 x USB 2.0 ports
1 x microphone
1 x Line-in Jack
1 x headphone / line-out jack with SPD-F support
1 x DC-in jack for AC adapter
Thanks for your help.
e-x-daiann@hotmail.com
