I recently upgraded to 3.4.2.0 from 3.3.3.0. Flac exporting no longer works for me - there is some horrible static that makes the audio unusable - and I can no longer click on a file in the Finder and press play. I tried going back to 3.3.3.0, but exporting is still producing the same issues. I now have to export to WAV and then use ffmpeg to convert the files to flac, which is inconvenient to say the least.
Testing on W10 with 3.4.2
I cannot reproduce this - FLAC export works fine for me - and I can successfully re-import the FLAC file.
Peter.
Could well be a Mac thing? This is a Mac subforum, isn’t it?
It is indeed - I can test on my Macbook Pro later if I get time.
In the meantime - have you tried the flac options in the Custom FFmpeg export:
See this page in the Manual for details:
https://manual.audacityteam.org/man/custom_ffmpeg_export_options.html
Peter
I just tested with 3.4.2 on my Macbook Pro running macOS 12.7 Monterey
And FLAC export and re-import work fine on that Mac.
Peter.
Thanks; I deleted my old version and preferences and re-installed; I have been upgrading this install for years, and some old and incompatible stuff must have been carried along.
Glad you got it working - and thanks for reporting back.
Peter
