I have a sound file that was over-amplified when originally recorded. I’ve tried various filters, but still sounds pretty bad. I’m using the free version of Audacity. Does anyone know if the another version of Audacity - or any other kind of software - has the ability to make it usable? I need to remove the distortion. It is a recording of a wedding, so has lots of sentimental value.
BTW it is possible to attach a few (10?) seconds of audio (e.g. WAV or mp3) to a post here if you put it in a ZIP file.
If you posted a bit of your wedding audio people here may be suggest treatments, or tell you if the patient is terminal.
Wow, thanks for such a quick response! I’ll get a snippet and post it when I’ve got a little more time. But I did take a look and couldn’t find a “clip fix” tool. I have Audacity 1.2.6, is that only in another version?
Thanks again, I’ll the the clip out as soon as I can.
Audacity 1.2, although officially “Stable,” is hopelessly out of date. Audacity 1.3 has all the cool tools and talents. Even though 1.3 is officially “Beta Unstable,” it is the basis if the soon to be released 2.0 stable.
I can hear the distortion you’re talking about, and I think I can see it in the waveform. It’s not clipping, so the Clip Fix tool will be no help.
I think the distortion originates in the microphone. Either the microphone was unable to cope with the very low frequencies and created its own internal weird distortion, or the microphone stand was vibrating. The distortion seems to occur during the lowest notes. Rolling off the lowest frequencies is no help.
That sounds like a pretty cheap microphone as well. No high frequencies to speak of. An organ shouldn’t sound that muffled. Perhaps it was a microphone placement issue. The file does benefit from some pretty radical high frequency boost (the organ sounds way better) but the hiss comes up to annoying levels.
You might be able to salvage the recording, but you’re never going to be able to get rid of that low-frequency distortion. High-frequency boost (+20 dB at 5 kHz shelf), makes it sound better but, as I said, brings up the hiss. You could apply an EQ curve you like to the entire file to get it to sound decent, then try to use Audacity’s Noise Removal tool to get rid of the hiss. It’s up to you to decide if it’s worth all that work.
“You can’t make a silk purse out of a sow’s ear”. Don’t believe the things you see them do with audio on CSI - it’s all fantasy.
I, too, think the microphone wasn’t up to the job. Each church has resonance and good organists play to those notes. This can drive sophisticated microphones; condenser, electret, nuts. I hear frequency doubling where the low pedal which should have been. The bass note through the middle of the clip was instead an octave higher and distorted. Anyone else notice the last note at around 9 sec isn’t mangled? That’s where the performance slid off the resonance of the room and just became normal sound.
I expect a dynamic (moving coil) or ribbon to be the only two microphone types to be able to stand up to that kind of punishment and even with that, some steps would need to be taken to avoid overloading the preamplifier.
You can probably get really good condensers to survive this, too.
Not the microphone on top of the camcorder. That’s what this was, right?
A good dynamic microphone would be a good choice, though many of the cheaper ones have poor high frequency response. Ribbon microphones and some condenser microphones are capable of the job but are expensive and delicate.
Most stand-alone microphone pre-amps should be able to cope, but metering can be a problem as often the meters do not respond accurately to very low frequency sound and setting the recording level often requires an element of guesswork. To get a really good recording of a big organ requires very high quality equipment. The dynamic range and frequency range of a big organ is extreme, so it will show up any weaknesses in the equipment. Having said that, good results can be achieved with mid-range equipment provided everything is set up carefully.
If someone who knows nyquist could modify Mr Sky’s plugin to include a reciprocal term, so it divides rather than multiplies, then possibly it could then be used to cancel out such bass-induced vibrato-like distortions when used in lowpass mode.
This is a long shot, but is the only thing I can think could possibly correct the distortion in the wedding music.
As said already, you can’t repair this fully … just try to make it sound better.
I would try some spectral repair tools found on iZotope RX and Adobe Audioion 3.
I was hopeful, but not really expecting much from this recording. Just too bad I can’t go back and do it over.
I don’t know what kind of microphone it was, but it wasn’t expensive. Simply plugged into a cassette recorder 35 years ago to record the vows and music from a wedding. Before the days of elaborate videographers and equipment…
Thanks for your suggestions, I will give them a try. You’ve all be very helpful.
Ah, it all starts to come together. An “archival” recording, worth trying to salvage. Begin by working on small sections of the organ part and the vows part until you find settings that work for you.
First, try the High Pass filter with a Rolloff of 12 dB and a Frequency of 100 Hz. That will mitigate the low frequency badness.
Next, go the the Equalizer effect. Click the “Flat” button then switch to “Draw curves” view. Click on the line at about 800 Hz. Click and drag upwards at about 2000 Hz, dragging a point up to about +12 dB. If you don’t like what you hear, Undo and try a slightly different curve. When you find one you like, save it. See http://manual.audacityteam.org/index.php?title=Equalization
Try both effects on different sections of the recording. You may not need the high-pass filter when the organ is not playing. You may want different Equalization when the organ is not playing.
When you’ve figured out what parts of the recording need what treatment, start over (Undo back to when you opened the file, or close without saving changes and open again) and apply the effects as and where needed.
Finally, you may want to apply Noise Removal during the vows. The high frequency boost that was applied by the Equalization effect will really bring up the hiss. Don’t try to remove the hiss, just try to bring it down a bit. Check this page http://manual.audacityteam.org/index.php?title=Noise_Removal .
The result will be far from perfect, but may be more listenable than the original.
