Exporting clips placed on the same track
Hi,
in Audacity 3.5.1 on Linux I have a track with a large number of clips, called “1”, “2”, “3”, …
like this:
exp
Is there a way to export all the clips at once as separate single wav files?
Otherwise I have to do it by hand one by one…
Thank you,
G
You could move each clip to its own tack and then use Export Multiple (based on tracks).
And if you want them all back in the original place just use Undo the requisite number of times (or save the project prior to the moves, exit Audacity after the export without saving, then relaunch and reopen the project).
Peter
