Version 3.5.1.
Just 2 days ago I was able to export labels via
File/Export Other/Export Labels…
Now that menu pick is grayed out.
Why is Export Labels disabled now?
Reverting to 3.4.1 did not help.
I now do Edit/Labels/Export Labels five backtabs etc.
A little inconvenient but I’ll survive.
I still would like to understand.
(I don’t want “regular interval labels”, I want MY labels.)
I don’t know if this is one of the “modules” but lately we’ve seen problems with exporting certain audio formats.
So this is just something you can check -
Go to Edit → Preferences -Modules and make sure everything is enabled.
April 26, 2024, 3:35pm
3
Ensure that you project actually has some labels.
What appears to be the problem is that you cannot see the Export Labels command active and available for use unless you have either:
a) at least on label track selected, or
b) have your cursor somewhere in any of the label tracks
Since there is no mechanism for exporting selected labels this seems a bit odd and unnecessary - and Export Audio works even if no audio is selected - I will find some time to log it as an issue.
Here is the issue I logged a while back about exporting selected labels:
opened 03:33PM - 29 Aug 21 UTC
bug
P3
Labels
import-export
**Describe the bug**
Export Labels cannot export selected label tracks or selec… tions within label tracks.
This is inconsistent with what Audacity offers for audio with "Export Selected Audio"
This was originally logged on Bugzilla as P3 2771
https://bugzilla.audacityteam.org/show_bug.cgi?id=2771
**To Reproduce**
Steps to reproduce the behavior:
1) create a project with three label tracks
2) place a distinct label or labels in each label track
3) select any one of the label tracks (or click and drag to select a range of labels in one of the label tracks)
4) File > Export > Export Labels
5) Open the labels TXT file
6) Observe: all labels from all three label tracks have been exported
**Expected behavior**
The ability to export:
a) Selected labels
b) all labels in selected label track(s)
**Screenshots**
Not applicable.
**Additional information (please complete the following information):**
- OS: all OS
- Version all Audacities (including 3.0.4 current release)
**Additional context**
The Steps to Reproduce are a simple and trivial use case - but this issue arose from rescuing a corrupted AUP3 project for a user. The project had three dense label tacks with many hundreds of markers.
In order the rescue the project from our salvage operation the user had to export WAVS and labels from the salvaged project for re-import into a clean new safe project.
The only workaround was:
Temporarily delete all but one label track and export that, use Undo to restore the temporarily deleted label tracks. Repeat for each label track in turn.
Peter.
I forgot, I already logged that back in November last year.
opened 12:30PM - 27 Nov 23 UTC
bug
Design / UX
regression
Labels
import-export
### Bug description
With the **New Export** introduced in 3.4.x Export Labels … is inconsistent with Export Audio - and is unavailable with no labels selected.
a) It is impossible to export a selected set of labels or label tracks (as is the case for audio).
Export Labels _**always**_ exports _**all**_ of the labels in all label tracks.
b) some controls, the **Exported Label Style**, is "hidden" away in preferences, **Import/Export** prefs.
Compared to Export Audio where the user now has full control in the dialog with no hidden settings.
c) If no labels or label tracks are selected the Export Audio in the Export Other sub-menu is grayed-out and unavailable.
This is a regression on 3.3.3 introduced with the New Export changes for 3.4.0
### Steps to reproduce
1. get some audio
2. add a couple of range labels "A" and "B"
3. add a new label track
4. create a range label "C" in that track
5. select the audio track
6. File > Export Other
7. Observe the Export Labels is grayed-out and unavailable **(this is use case **c** above - the regression)**
8. Select any one of the three labels
9. File > Export Other > Export Labels
10. Observe: the exported labels.txt file contains all three labels - _**not**_ just the selected one
### Expected behavior
Draft of proposed Export Labels dialog
This would have the advantage of being able to remove the **Exported Label Style** block from **Import/Export** preferences
### Actual behavior
And further details in STRs above
### Audacity Version
3.4.x all versions and 3.5.0 alpha
### Operating system
Windows 10 - but assume all OS
### Additional context
Use case **c**, the regression, above was originally reported today by a user on the Forum:
Exporting Labels (Aud. 3.4.2 / Mac)
https://forum.audacityteam.org/t/exporting-labels-aud-3-4-2-mac/91204/1
See also:
**New Export - changes could be extended to Export of Labels and MIDI #4891**
Flagging @LWinterberg and @Tantacrul as a Design/UX issue
Peter
Thanks. That was it!
Must click in the Labels track first.
system
Closed
May 27, 2024, 11:52am
8
