Exception code 0xc0000005 on exit, version 3.5.1
I edit audio once a week at my office. For the fourth week in a row, I’ve gotten this exception code upon exit (after saving my project, exporting audio, and being asked if I want to save my project upon exit [yes]). The Problem Report for Audacity window pops up, but when I click [Send] I get an error “Failed to send crash report”. Same error occurs if I attempt to send the crash report again.
The first week I simply clicked [Don’t send] and went about my business, but the second week when I opened Audacity there was a file to recover. I recovered it, then did my weekly audio editing. Same error occurs each week upon exit. Same error occurs when I try to send the report. Each time now I copy the text of the Problem Report and save it (in case it can be sent some other way).
This week (5/21), I saved my project, then exited Audacity before exporting the audio from my project. The exception code error recurred as before.
I’m running Windows 11 Home on a fairly new computer (less than a year old). There are 702 GB free on the data hard drive, and it is optimized weekly by the operating system.
I believe this error has occurred every time I’ve edited audio with this latest version of Audacity (3.5.1), but I’m not 100% sure of that. If there’s some place I can send these error reports I’ll gladly do it.
I’ve just experienced exactly the same behavior with Audacity 3.5.1 on Windows 11. When I attempted to open the aup3, I had to recover it. Closing after that happened without an error, as did reopening and closing again. I’d post the error log, but I don’t see how to do that. I’ve used Audacity for many years without an issue, and I don’t think I’ve had a problem in 3.5.1 before now. Windows 11 has been updated as Microsoft decides to, so there has certainly been an OS update since the last time I used Audacity.
It’s nice to know I’m not the only one experiencing this! It happened again today. At least it doesn’t seem to be affecting exported audio files, and my original audacity files seem fine once they are recovered.
But it’s certainly an annoying extra couple of steps each week!
Hopefully we’ll get some answers soon from Audacity.
I’m experiencing the same problem… Hope someone will figure it out.
Me too, Sam.
It continues to happen every week, each time I edit a new audio file. I now have 8 error files saved that wouldn’t send.
This was only happening for me on occasion. I just had this happen on the last 5 mp3 files I edited.
Getting this exception code, but when I choose to send the error report, it claims it can’t send it now.
Windows 11 Pro on Lenovo way overkill CPU and RAM. I can run Pro Tools and Reaper fine. Error just with Audactiy.
Well, this exception also occurs under Windows 10. I am curious if and when there will be a solution. As the sending of the debug data does not work, I copied the entire text to a text file - just in case. Is there a place to drop this information off?
Sorry you have joined the group of users experiencing this!
I, too, have been saving the debug data to a text file each week when I get the error again. As none of the Audacity staff have replied, I know of no place we can send this data in order to facilitate a solution.
We can only hope that Audacity staff will soon reply.
I just upgraded to 3.6.1, hoping that it would solve the problem. I edited a new sound file today, then exported the audio to my computer and exited Audacity.
Sadly, it doesn’t fix the error. It didn’t even solve the error report failure, so I saved the error information yet again. sigh
I don’t see a way to change my title so I can indicate the problem is continuing in 3.6.1.
Audacity staff, are you seeing this problem report? Can it be escalated, please?
Are y’all using network, external, or cloud drives? Audacity hates that.
The latest “Cloud Saving” thing doesn’t count. That is a special purpose service on audio.com and only used for Audacity Projects.
I think I would decelerate back to Audacity 3.4.2 and then Tools > Reset Configuration. See how that goes.
Get the older Audacity from here.
If you have crashes on Windows, you should do a clean shutdown to sweep away broken file fragments. If you don’t, the fragments will make further crashes more likely.
Post back how it goes if someone tries it.
Kozikowski,
I’m using a hard drive on my computer, not a network, cloud, or external drive.
Windows itself is not crashing, just Audacity. I’m not sure what you mean by a “clean shutdown”. I shutdown my computer every time I leave the office, so if that’s what you are meaning it doesn’t apply to this issue.
I don’t have time this week to try installing an old version of Audacity. Perhaps next week.
Good start. The cloud people go to a lot of effort to make their cloud offerings “look like” a regular internal drive.
To be clear, Audacity thinks any drive it can see can be used for any job, no matter how delicate, critical, or difficult. Suddenly discovering that your tightly-controlled musical overdubbing job is being managed from a cloud drive outside of Schenectady is not good news. Blammo!
Nobody wants to wait for Windows to “start over” each time it, well, starts over. So Windows leaves portions of itself running, set up, or in “hibernation.” That’s fine as long as nothing ever goes wrong. The first time you have a crash or other serious problem, it may leave shards and trash over the system which a quick, convenient shutdown may not catch. This can lead to more frequent or deeper crashes.
Ctl/Alt/Del from a
That’s not the only way to do that. Search for “Clean Shutdown.”
Audacity problems started in the 3.5 series and have been getting far worse as the versions progressed. Stepping up to the latest version is not going to solve all your problems. The Audacity 3.6 series destroyed several of the Audiobook production tools which I am scrambling to rewrite.
So that’s where we are.
I’ve been having the same issue for a long time now. Nothing anyone has suggested has fixed it. It started in the middle of editing an audiobook. Several times I thought i had uploaded clean exports but because of constantly having to recover files my debreather tool had been moved all over the flipping track, I am so very done with audacity because of this issue. Just about every time i close audacity it fails to close properly and i have to recover the track.
OK rant over.
I am using a new computer with a fresh intall of windows. Besides firefox the only other thing i installed on here was audacity to get it set up for work.
Crash report states EXCEPTION_ACCESS_VIOLATION_READ if that helps figure out why this is happening.
I am receiving this as well. I’m a podcaster. No music at this stage, just two tracks of dialogue.
Good news, fellow sufferers!
Today I updated to Audacity 3.6.4 before I did my audio editing for the week.
When I exited Audacity, NO ERROR REPORT!
I didn’t have to do anything special other than updating to the latest version of Audacity. Note, however, that I turn off this computer each night before leaving the office (not hibernation or “sleep”), so if you don’t do that your mileage may vary. See kozikowski’s comments above.
To make sure, I restarted Audacity, and there was no file to recover this time, confirming that it didn’t crash upon exit.
I hope you all have the same happy result!
Once.
Post back when Audacity continues to behave properly over several shows or productions. There are several postings from people who got all excited about an apparent success only to have the next show go straight into the gutter.
Pay obsessive attention to your machine if you install other software, or do other jobs. You are now the test case.
I have an upside down servicing technique I sometimes use. If somebody wrote me a big check and told me to intentionally cause this problem, how would I do it.
I can’t cause these failures. No simple error I know of can cause this much damage to so many different machines.
Good luck.
Audacity has continued to not crash upon exit. Audacity 3.6.4 has been the solution.
Very thankful to put this annoyance behind me.
I installed Audacity 3.7.0 today, then performed my weekly audio editing.
The crash is back! Same error, same behavior of the problem report failing to send (so I once again saved the report data should it ever be needed).
If you had this error before, I suggest NOT “upgrading” to 3.7.0!
I installed Audacity 3.7.1 last week. Although editing proceeded as normal last week, the crash occurred upon exiting after this week’s editing session.
If you have experienced this error, I recommend not upgrading to 3.7.1. I’ll be returning to 3.6.4 until another upgrade is available to test.
