I keep trying to play my song and it keeps saying, “Out of memory! Error while Opening sound device. Please check out Output Device Settings and the project sample rate.”
This makes no sense, since this is my first mix. With only two songs being mixed.
I’m new at this and I’ve looked up this a lot. But none came up. So I thought this could help.
I’m using windows vista. And Audacity is version 2.0.3.
Help??
Please be as detailed as possible in steps. This is really confusing me.
May 9, 2013, 5:19pm
2
Topic moved to the Windows forum.
Can you sometimes play back from Audacity, or does this error occur every time?
Do you know what sort of sound card you are using?
steve:
This message happens everytime and no, I don’t. sorry.
May 10, 2013, 12:35am
4
Please would you do the following:
Launch Audacity
Help menu > Audio Device Info"
Copy the “info” from the window that appears and paste it into your reply.
Also, what settings do you currently have, and what other settings are available in the Device Toolbar ?
steve:
Launch Audacity
Default capture device number: 1
Default playback device number: 5
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.200000
Low Output Latency: 0.200000
High Input Latency: 0.400000
High Output Latency: 0.400000
Supported Rates:
Device ID: 1
Device name: Microphone (Webcam 250)
Host name: MME
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 2
Device name: Mic 1 (Live! Cam Virtual)
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Device name: Line 1 (Live! Cam Virtual)
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 4
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 5
Device name: Speakers / Headphones (SigmaTel
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 6
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 7
Device name: Digital Output Device (SPDIF Ou
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 8
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Input channels: 1
Output channels: 0
Low Input Latency: 0.000000
Low Output Latency: 0.000000
High Input Latency: 0.000000
High Output Latency: 0.000000
Supported Rates:
Device ID: 9
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 10
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 11
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 12
Device name: Primary Sound Driver
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 13
Device name: Speakers / Headphones (SigmaTel High Definition Audio CODEC)
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 14
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 15
Device name: Digital Output Device (SPDIF Out) (SigmaTel High Definition Audio CODEC)
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 9 - Microphone (Webcam 250)
Selected playback device: 7 - Digital Output Device (SPDIF Ou
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available capture sources:
0 - Master
Available playback volumes:
0 - PCM
Capture volume is native
Playback volume is native
And my settings are:
MMe
digital output device (sdpif) ou
microphone webcam
input mono; 1-mono imput channel
May 12, 2013, 4:36pm
6
Try disconnecting your webcam and reboot the computer. Does it work now?
May 13, 2013, 11:54am
8
Could you post the “Audio Device Info” that appears with the webcam disconnected.
This?
Device ID: 0
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 1
Host name: MME
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 2
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 3
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 4
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 5
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 6
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 7
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 8
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 9
Input channels: 1
Output channels: 0
Supported Rates:
Device ID: 10
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 11
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 12
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 13
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 14
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 15
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 0 - Microsoft Sound Mapper - Input
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
0 - Master
0 - PCM
May 13, 2013, 2:26pm
10
Is your webcam physically disconnected, or does your computer have a built in webcam or something?
See where it says:
Device ID: 1
Host name: MME
Input channels: 1
Output channels: 0
What is that?
steve:
See where it says:
Device ID: 1
Host name: MME
Input channels: 1
Output channels: 0
What is that?
Phsycally, and I have no idea. It was in the aduio device setting with everything else.
Other songs can work tho.
