Grafic EQ and Filter Curves EQ rename all clips after applying. Is this a program error?
Looks like a bug to me - I’ll log it on GitHub issues shortly
Peter
Logged on GitHub
EQ effects rename all clips #3796
https://github.com/audacity/audacity/issues/3796
Good catch Ruslan
Peter.
Logged on GitHub
EQ effects rename all clips · Issue #3796 · audacity/audacity · GitHubGood catch Ruslan >
Peter.
I’m looking forward to fixing this bug ![]()
Look at Renaming a clip does not work again, it’s also related to renaming. If you write an e-mail, I can send you a project on which an error occurs.
I will send you a PM on the Forum with my email address.
And as you can see, renaming worked on my test project created to log this bug with EQ renaming clips. And I have never experienced any failure to rename clips, so I am puzzled by your experience
Peter.
