efecto filtros clásicos (classic filters effect)
Buenos días.
Ahora no a parece en el listado de efectos el efecto filtros clásicos.
Audaciyt 3.1.3 rodando en Windows 11
Hello.
Now the classic filters effect does not appear in the list of effects.
Audacity 3.1.3 rolling on Windows 11
Perhaps you are looking for Filter Curve EQ and/or Graphic EQ.
=== Google Translate ===
Quizás esté buscando Filter Curve EQ y/o Graphic EQ.
In 3.1.3 and earlier the Classic Filters effect was not enabled by default.
To enable it:
  1. Effect > Ad/Remove Plugins…
  2. Click on the “New” radio button
  3. Click on “Classic Filters”
  4. Click the Enable button
  5. click the OK button
and then you;re good to go with Classic Filters
BTW the latest version of Audacity is 3.2.1 (with 3.2.2 soon to come) and that automatically enables Classic Filters
Peter.
