I installed v.3.2.0 today and find the Edit Toolbar no longer contains Cut, Copy and Paste buttons. Have they been removed? If so, why, or am I missing something?
Yes, Muse removed these in 3.2.0 to “simplify” the interface.
You can use the shortcuts:
Ctr l+ X is cut
Ctrl + C is copy
Ctrl + V is paste
which is waht most users use
Or use the commands in the Edit menu
If you want single key shortcuts you can always create custom shortcuts:
https://manual.audacityteam.org/man/keyboard_preferences.html#custom
Peter
Thanks Peter, I didn’t think the interface was complicated. I’m aware of Ctrl+X, etc. but nearly always click the buttons with my mouse. Using the commands in the Edit menu involves more navigation, so I’ll regress to v. 3.1.3.
If you don’t want to move your mouse much, right-clicking in the track is even less cursor movement.
Thanks for the suggestion.
