I’m finding it harder to get digital mixes just as I like them, whereas I found analogue easy from the off, so I don’t think it is purely a personal experience thing.
In particular the levels of different instruments seem to vary more when played back at different volumes on digital mixes
I don’t mean the relative differences between loud and soft passages, it is noticeable across entire mixes.
Is this a compression issue?
I never used compression in my analogue recordings (nor yet on digital), would it be the compression inherent to cassette tape making the difference and what would be the digital compression parameters that equate to tape?
Maybe I’m barking up the wrong tree but something is something is different between the two processes.
Lets say we have a recording with guitar, vocals, keyboard & drum tracks
What would be a good max level for each before mixing digitally?
Theoretically, it’s the same. Mixing is done by summation (addition). Computers are pretty good at addition! An analog mixer is built-around a summing amplifier, and when two sounds mix acoustically in the air, the waves are being summed. i.e. If you reverse the polarity of one speaker you are “adding a negative” and you can hear the bass subtraction. You can hear cancellation at higher frequencies too, but room reflections and distance variations give you a spacey/phasey sound as different frequencies are canceled more than others.
In the real-world, Analog mixers typically have more headroom than digital formats. Since you are adding signals, you can easily end-up with clipping (distortion) when you mix digitally. Audacity works in floating-point (like most audio editors), so there is virtually no upper limit and Audacity won’t immediately clip when mixing. But if you export to a normal integer format, or send the full-volume signal to your DAC, mixing can cause clipping.
Yes, analog tape can introduce some compression. That would show-up as a difference between what you are hearing “live” from the mixer compared to what ends-up on the tape.
The cassette is going to have more noise and frequency response variations that you don’t get with digital recording… Those are the things you’d probably notice if for example you transfer a CD to a cassette.
P.S.
And, there may be some other difference between you digital setup and your analog setup… And, it’s very unlikely that you are mixing & recording the exact same signals!
…and what would be the digital compression parameters that equate to tape?
It’s hard to do with a regular compressor/limiter. You can find tape simulation plug-ins, and that’s probably the way to go if you want to simulate analog tape. Usually these simulators are designed to mimic particular high-end studio reel-to-reel tape decks, and I’m just not sure if you’ll find a cassette simulator.
Tape acts like a limiter with a soft knee. But it gets more complicated because the recording equalization (high-frequency boost & low-frequency cut) means that high frequencies are saturated at lower levels than low frequencies. And, the playback EQ (high-frequency cut & low-frequency boost) tends to “soften” the distortion caused by saturation/limiting.
Gets complicated doesn’t it? At least for me it does.
Thanks for taking the time to explain things doug.
Maybe you have covered it and I haven’t gotten things but I’m still wondering though about the relative playback volume levels.
On my fuze mp3 player I have several tracks recorded and mixed on the computer and several recorded and mixed on tape and tranferred to the computer.
The tape sourced tracks sound fine at lower volumes, the digital ones don’t sound so good at lower volumes. They’re better when driven with more volume.
I think you’re listening to a combination of tape characteristics and your ear’s oddities.
Loud always sounds good. That’s why the store makes the sound system they want to sell quickly louder than the others.
Tape systems are not linear. They have a graceful “S” curve and it’s your job to keep the show in the more or less flat, straight portion in the middle. So the shows are “compressed.” Sharp, high peaks are reduced and there isn’t much you can do about it. And you may not want to do anything about it. That “distortion” sounds pretty good. Also remember when you edit tape, you’re going through all the tape electronics multiple times.
You stopped short of a definitive test. Tape dub the same song back and forth six or eight times to really see what the machines are doing to it. If you do that to the digital version, little or nothing happens. Something is going to happen to the Audacity digital version. Audacity adds a dithering signal to the export to get around digital conversion errors, and that will eventually add up. But I think the analog show is going to fall apart way sooner than the digital.
I wonder what would happen if you applied one of the “tape effect” filters to your digital work.
My ears can be a bit odd at times, they are highly/over- sensitive, a legacy of having had Myalgic Encephalomyelitis. I don’t care for a lot of current productions even when I like the song.
It’ll be a month or so before I’ll be reunited geographically with my tape deck
so will experiment with copying digital mixes to tape then. Not to see which format ‘falls apart’ first but to see what it does to the sound.
In the meantime I’m trying out vintage warmer. Thanks for the suggestions koz
I like that the video makes it clear that the Vintage Warmer is a “distortion” effect (albeit a very subtle one). Far too often “analog warmth” is wrapped in mystical reverence that denies that fact
When audio is played in a real environment it gets modified, perhaps even distorted. There are some elements of that real life modification that digital doesn’t capture properly IMHO. That’s probably why some people think analogue sounds more natural, warmer or whatever, even if it has other distortions that are perhaps unwelcome.
I think you know what I mean by now. Fundamentally, “poor” or “artificial-sounding” representation of “sound stage” (where the instruments are placed left-right and back-front in a believable ambience, and how the instruments blend into each other).
Digital vs Analog is irrelevant to both of those concerns, though there may be a tendency for engineers/producers that prefer analog equipment to have different ideas about spacial separation than those that prefer digital equipment.
Professional level equipment is designed to be “accurate”. That is, to not colour or distort the sound, but to faithfully reproduce the signal that is put into it. Modern professional recoding equipment, whether digital or analog, does this extremely well. All else being equal, I doubt that anyone can hear a difference between music recorded on a Neve 88RS and music recorded on a Neve 88D. On the other hand, I can clearly hear the difference between an over-driven solid state pre-amp and an over-driven tube pre-amp because they have distinctly different timbre (the way that they colour the sound is very different).
Ooh I do like riding this hobby-horse around the paddock …
My touchstone for this is my LP and CD of Sonny Rollin’s album “The Bridge” - a fabulous performance combined with fabulous engineering - and the re-engineering for CD is truly excellent too. As you know I listen on fairly high-end (if ancient) QUAD kit with ESL-57s - I find that both media versions provide and excellent “sound stage” - if anything the CD has a better “grip” on the “sound stage” - and it’s certainly cleaner after many years of playing the LP. I’ve also played this CD on a friend’s extremely high-end kit and the CD sounds stunning there too.
The ability to create the “sound stage” of course originates in the recording and engineering - but once the album is in the consumer’s hands the ability to create a good “sound” stage is largely governed by the quality of the kit (DAC-amp-speakers / cart-arm-amp-speakers). I was amazed, for example, when I swapped out my original Philips 104AB for my Rega Planet CD deck at how much better the Rega was (and still is) at creating the “sound stage”
Another irony, BTW for the pro-vinyl bods, is that the modern generation of new vinyl albums which are becoming so popular are (mostly) produced and engineered in digital technology before pressing in analog vinyl.
Is the LP an original issue (from 1962, according to Wikipedia)? If not, “soundstage” often becomes much thinner and generalised on LP reissues - one disadvantage of the LP medium for reasons that are not always clear.
The most insane LP buffs can hear differences between different stamper numbers on the same release pressed the same year.
I agree with you there. For the same reason as I give above, I sometimes think even “all analogue” 180 gram vinyl reissues of 1950’s/60’s recordings are inferior to CD (and even more inferior to the original vinyl, considering only “sound stage”).
Was rather than is, yes it was the original release - but I lost it a few years ago (through divorce, but hey it was hers in the first place) so I can no longer make the comparison - plus my record deck is no longer plumbed in, or plumbable in, to my hi-fi rig.
Yes and one can hear differences if the pressing has not been made properly - in extreme cases with a “cold pressing”. It was the fact that I was getting too many cold pressings, sometimes taking an album back to the shop for a fresh copy two or three times, that provided one of the reasons for me to transition to CDs.
