Hi I love the new features in 3.4.2 I’m happy that the classic filters were preserved.
Where is the desibilator effect filter? I miss it. If it is discontinued, can you recommend a de-ess method or something comparable to the pro tools plug-in soothe. Hot s’s are a nuisance.
Thank you for your time and your detailed response. I went to toneboosters - support - legacy, and downloaded the bundle. I then went to Audacity - tools - nquist plugin installer. I found the bundle in Program Files/ Toneboosters/ Sibilance (I did not see TB_DeEsser_v3) The file name wouldn’t change to reflect the Sibilalnce exe? file. No matter what I clicked on / selected, the file name remained untitiled.
You Jedi Windows Wizards make it sound easy… but I get lost in the intriciasies.
I’m using a Dell G16 / Windows 11 Home / 64 bit OS
Quoting Danzel W in “Philadelphia” “Please, explain it to me like I’m a 4th grader.”
The ToneBoosters plugins are not Nyquist plugin, they are VST2 plugins.
The nyquist installer is not used to install VST plugins.
Unzip this file from Toneboosters … https://www.toneboosters.com/downloads/TB_Installer_v1.6.0_legacy_win.zip (VST2 not AAX)
It contains “ToneBoosters Legacy Plugins Installer.msi” running that installs the plugins …
