Dark mode from version 3.5.1
yes, it will
Wonderful. The MUTE track button also is no longer working in 3.6.2. The SOLO button does not select a single track and mute the other tracks in a project. You have to hit the SOLO button on the other tracks to mute them.
@CLUBROCKER
Mute button works for me in 3.6.2
Maybe you need to go to Tracks Behaviors preferences and set the Solo Button back to Simple - Muse changed the default to Multi-track a while back to make Audacity behave more like a mixing desk by default.
See: Tracks Behaviors Preferences - Audacity Manual
Peter
Thank you so much! That solved the issue. It seems all my previously set preferences were reset in the last update.
Can you advise what setting can be altered in Windows 11 or Audacity that forces Audacity to open the modern File Explorer in dark mode?
I just updated to 3.6.4. I use the β€œDark” theme and the waveform color used to be orange with a black background. The new version displays the waveform in purple and a dark gray background. Is there an easy way to get the old Dark theme colors back? TIA!
