Creating a marker to align multiple tracks
I’ve got four choral practice tracks–SATB–and I’m trying to line them up manually so they’ll synchronize.
I just want to have a vertical line that goes through all four tracks to use as a reference when I do this. Is there a way to make a bookmark of some sort?
Place your cursor at the required start point.
Create a label (Edit > Labels > Add Label at Selection) there.
As you drag the start of each track in turn you will get the yellow snap line showing thought the tracks to aid alignment.
Peter.
