Connecting Audacity to JACK Audio Kit
Hello,
I need to work with JACK Audio Connection Kit for a college project and I’m not sure where to start. From this page I know that CoreAudio is the only available choice in MacOS. Is it still possible to somehow connect Audacity to JACK?
I haven’t heard much about Jack under MacOS. For additional insight see: JACK and Audacity – Justin S Barrett and JACK audio support in windows builds
Report back what you find.
That sounds like a very strange requirement unless you are using Linux. Jack Audio System is available for macOS, though it is rarely used.
If Jack Audio System is installed and running, it should show up automatically as a “host” option in Audacity. I don’t know if it actually works as I’ve never come across anyone using Jack on macOS.
