On compressing stereo material since quite some time I observe that the stereo image is getting damaged using the compressor. Please correct me if I’m wrong.
There should at least be a check box enabling the algorithm to process both stereo channels individually or linked together (should be default): If processed individually peaks on the left or right channel will trigger gain reduction on that specific channel only - affecting the stereo image and rendering the built in compressor useless for stereo material with defined objects (e.g. vocals) in that stereo track.
Dear developers, would you mind implementing a checkbox for linking the stereo compression?
