Commercial Purposes question
Hi there! How’s it going? I just registered because I wanted to ask this question. (I’m also not 100% sure where exactly to post this question)
I’m 99.9% sure the answer to this question is yes, but I still want to ask.
So I can see in the license section that it says that Audacity can be used for Commercial purposes, which is def great to know. ^^
Though my question is just a bit specific… and maybe not a required question, but I’m going to ask it anyway.
Does the ability to be able to use it for commercial purposes apply to every version of Audacity that’s ever been released?
Just wanted to make sure.
I’m not able to check the very ancient versions, though I believe that Audacity has always been released under a “GNU General Public License” (GPL).
I’ve checked in Audacity 1.2.5 (released October 2006) and that is GPL.
Even Audacity 1.0 was released under “GNU General Public License” - I just checked in its help file.
Update: And indeed so even were 0.8 and 0.98 Audacity
Peter
Gotchya! So I guess the “using it commercial purposes” aspect applies all the way back to that?
(I assume that’s what’s meant by “GNU General Public License”, amongst other things… haven’t studied that term much…)
The full details of that license are here: https://www.gnu.org/licenses/old-licenses/gpl-2.0.en.html
Gotchya! Looks like that definitely confirms that it does apply to all the versions then, at least down to 0.8 hehe.
Thanks for the help in confirming ^^
