Hello folks!
First I need to be clear that this problem has nothing to do with Audacity itself, it simply evidences itself when I record with Audacity as well as other recorders, and I can see it visually using Audacity when I post-process. I occasionally record directly with Audacity (I did so in this video) and always use it to post-process my Audio (noise remove, normalize, compress, equalize, normalize again). If this is the wrong section of the forum for this I apologize - please direct me to the correct one.
I am using Windows 7, Audacity 2.0.4 and I obtained it from the .EXE.
I am a Youtube let’s player (I play video games and record commentary) and for a long while now I have had problems with clicks, beeps, and other noise artifacts in my audio. I will link below to a short video that gives both audio and visual (waveform, using Audacity and Sony Movie Studio visualizers) examples of these artifacts.
As the video explains, I’m looking for A) what is causing the noise? Is it mouth noise, a mic problem, a connection problem, something else? And failing that, B) what is the best way to remove it? I am currently just cutting them out of the waveform which works but is very labor intensive and occasionally produces a thud or gap in the audio that’s probably just as bad as the click it’s replacing.
https://www.youtube.com/watch?v=k2GETGley60
I appreciate any help you are willing to share. Thanks!
-Marcus
