Can't open aup3 files on mac
When I try to open my aup3 files on my mac in Audacity 3.7.x, I get message: “Cannot import AUP3 format. Use File > Open instead.” EVEN THOUGH I AM USING FILE > OPEN!!!
I tried reinstalling Audacity but I get the same error. How do I (a) get rid of all vestiges of 3.7x and (b) find 3.6?
TIA,
Gary
Rename “audacity.cfg” file in settings folder to, say, “audacity-old.cfg”.
( renaming rather than deleting allows you to revert back to the previous state),
If you actually made projects in 3.7.x they are not compatible with previous versions of Audacity.
