Every time I try to import an OGG file into audacity it stop responding. I am using audacity 3.2.0.
Works fine for me on W10 when I test on the released 2.3.0 version and the latest alpha test 2.3.1
Are you sure that it’s a valid Ogg file?
What do you mean when you say valid?
I put it through the website and it said the song name description genre ect. Also I tested another OGG and it did work.
Is it a secret what the web page said about the file?
Perhaps you could copy and paste the info (preferably using the “</>” button to put “code” tags around it, but don’t worry about it if you don’t know how to do that).
OK I found how to fix it thank you.
It could be helpful for other users if you shared that knowledge.
Sorry, I phrased that horribly, i just needed to find the tags of the song and audacity was the only way I knew to find those, however the website you sent me showed me the tag, and I think that you are right with the invalid OGG.
Thanks for the update. I’ll close this topic now.
