I’m running Audacity 2 on two PPC Macs - a 1 Ghz G4 eMac and a dual 2 Ghz G5 tower - and on both machines I’m unable to import MP3’s. It makes no difference whether I try from within Audacity (using the command from the File menu) or I right-click on the MP3 in the Finder and choose Audacity. Either way, Audacity launches (if I’m starting from the Finder), thinks for a few seconds, then quits.
If anyone can help me, I’d really appreciate it!
Here’s the crash log from the most recent attempt on my G5:
Process: Audacity [5020]
Path: /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier: net.sourceforge.audacity
Version: 2.0.0.0 (2.0.0.0)
Code Type: PPC (Native)
Parent Process: sh [5018]
Date/Time: 2012-04-30 11:46:21.516 -0400
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: 68287263-AC78-4CF3-813B-9BE808DFEA96
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7ffffc
Crashed Thread: 0
Thread 0 Crashed:
0 Audacity 0x0072f5b8 header_seek + 8
1 Audacity 0x0072ff08 psf_binheader_readf + 2004
2 Audacity 0x0076efb8 id3_skip + 64
3 Audacity 0x0075bf0c guess_file_type + 1136
4 Audacity 0x0075bf1c guess_file_type + 1152
5 Audacity 0x0075bf1c guess_file_type + 1152
... [This repeats over 500 times!]...
508 Audacity 0x0075bf1c guess_file_type + 1152
509 Audacity 0x0075bf1c guess_file_type + 1152
Thread 1:
0 libSystem.B.dylib 0x95ca6d00 open$NOCANCEL$UNIX2003 + 12
1 libSystem.B.dylib 0x95ceef90 fopen + 48
2 mod-script-pipe.so 0x016428e0 PipeServer() + 204
3 mod-script-pipe.so 0x01642a88 RegScriptServerFunc + 64
4 Audacity 0x003040f4 ScriptCommandRelay::Run() + 48
5 Audacity 0x002ab048 NonGuiThread::Entry() + 84
6 Audacity 0x005775d8 wxThreadInternal::MacThreadStart(void*) + 136
7 ...ple.CoreServices.CarbonCore 0x9487b384 PrivateMPEntryPoint + 76
8 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Thread 2:
0 libSystem.B.dylib 0x95ca6078 mach_msg_trap + 8
1 libSystem.B.dylib 0x95cacf9c mach_msg + 56
2 com.apple.CoreFoundation 0x97149394 CFRunLoopRunSpecific + 1812
3 com.apple.audio.CoreAudio 0x92871fa8 HALRunLoop::OwnThread(void*) + 212
4 com.apple.audio.CoreAudio 0x92871de4 CAPThread::Entry(CAPThread*) + 104
5 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Thread 3:
0 libSystem.B.dylib 0x95ca61f8 mach_wait_until + 8
1 libSystem.B.dylib 0x95d3158c nanosleep + 324
2 Audacity 0x0004ae8c AudioThread::Entry() + 140
3 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Thread 4:
0 libSystem.B.dylib 0x95caca8c __semwait_signal + 12
1 libSystem.B.dylib 0x95ce9318 _pthread_cond_wait + 1580
2 com.apple.ColorSync 0x946dd008 pthreadSemaphoreWait(t_pthreadSemaphore*) + 36
3 com.apple.ColorSync 0x946f0bac CMMConvTask(void*) + 48
4 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Is this one particular MP3, or any MP3? Does the crash occur if you try to import a WAV or AIF? Does a crash occur if you just try to start Audacity on its own?
– Bill
(Thanks for framing that console log!)
This only seems to affect MP3’s. AIFF’s and WAV’s import fine. I’ve tried a few MP3’s, all with the same result. However, all were recorded by the same digital recorder, a Sony ICD-PX820.
Forgot to mention that those MP3’s do open/play correctly in other apps. But before I can edit them in Audacity, I have to convert them to another format.
Also, I just tried to open, with Audacity, an MP3 generated by Audacity. Audacity paused, then quit.
May 1, 2012, 6:06pm
5
Yes - I didn’t try the one you linked to, but I just tried opening/importing two other MP3’s, and both worked just fine. Then I tried one of the problematic MP3’s, just to be sure, and Audacity quit, after about 20-30 seconds of the SBOD (Spinning Beachball of Death).
alterbentzion:
What happens if you use File > Import > Audio then choose “MP3 files” in the file types list?
Is it possible to upload one of the Sony-recorder MP3 files somehere, and also the one created by Audacity? Here are some free sites:
http://minus.com/
https://castle.so/
After that, is it possible to reboot the Mac?
And if that does not help, can you reset Audacity preferences as described here:
http://manual.audacityteam.org/help/manual/man/preferences.html#stored ?
Thanks
Sorry for the delay - the last few days have been crunch time for a project at work.
Rebooting: No dice.
File > Import > Audio: Same thing.
I’ve posted a set of files (original and exported) on a web server I have access to. (The recording happens to be one of some eulogies - “levaya” is Hebrew for “funeral” - and I doubt anyone who didn’t know Mr. Pollock will find them interesting, but I guess we can’t always choose the projects the come our way…) Here are the URL’s:
Original: http://kollel.shul.net/Resources/Levaya_H_Pollock_orig.mp3
Exported: http://kollel.shul.net/Resources/Levaya_H_Pollock_CVG.mp3
(As of 10:30 EDT, the “original” was stil uploading, with about 6 minutes to go.)
Thanks for the links.
Sorry to repeat, but have you reset the Audacity preferences? It’s important you do that. Quit or force quit Audacity, download the attached file then rename it to “audacity.cfg” (without quotes). In Finder, use Go > Go to Folder and type
~/Library/Application Support/audacity/
Open that folder. If there is already an audacity.cfg there, please rename it to “audacity_replaced.txt” and attach it to your reply for us to look at. Then paste the downloaded audacity.cfg file into that folder.
audacity (3).txt (23 Bytes)
I just tried your suggestion of replacing audacity.cfg; I paste the error report below.
Process: Audacity [9036]
Parent Process: sh [9034]
Interval Since Last Report: 1856120 sec
Crashes Since Last Report: 22
Per-App Interval Since Last Report: 17096 sec
Per-App Crashes Since Last Report: 5
Date/Time: 2012-05-08 13:38:50.618 -0400
Report Version: 6
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7fffe0
Crashed Thread: 0
Thread 0 Crashed:
0 Audacity 0x0072f5d4 header_seek + 36
<-- This repeats, verbatim, over 500 times. -->
Thread 1:
Thread 2:
Thread 3:
Thread 4:
Thread 5:
3 com.apple.CoreFoundation 0x97149c1c CFRunLoopRun + 60
4 com.apple.DesktopServices 0x953bb3ec TSystemNotificationTask::SystemNotificationTaskProc(void*) + 104
5 ...ple.CoreServices.CarbonCore 0x9487b384 PrivateMPEntryPoint + 76
6 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Thread 6:
4 com.apple.DesktopServices 0x953bb568 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 176
Thread 7:
2 ...ple.CoreServices.CarbonCore 0x9487d5a0 TSWaitOnCondition + 132
3 ...ple.CoreServices.CarbonCore 0x9485b91c TSWaitOnConditionTimedRelative + 204
4 ...ple.CoreServices.CarbonCore 0x9487d15c MPWaitOnQueue + 272
5 com.apple.DesktopServices 0x953c6ac0 TNodeSyncTask::SyncTaskProc(void*) + 88
6 ...ple.CoreServices.CarbonCore 0x9487b384 PrivateMPEntryPoint + 76
7 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Thread 8:
0 libSystem.B.dylib 0x95ca60f8 semaphore_timedwait_signal_trap + 8
1 libSystem.B.dylib 0x95ce9214 _pthread_cond_wait + 1320
2 ...ple.CoreServices.CarbonCore 0x9485b940 TSWaitOnConditionTimedRelative + 240
3 ...ple.CoreServices.CarbonCore 0x9487d15c MPWaitOnQueue + 272
4 com.apple.DesktopServices 0x953c8780 TFolderSizeTask::FolderSizeTaskProc(void*) + 88
Thread 9:
0 libSystem.B.dylib 0x95ce77b0 kevent + 12
1 com.apple.CoreFoundation 0x971209b0 __monitor_file_descriptor__ + 88
Thread 10:
0 libSystem.B.dylib 0x95d09c14 select$DARWIN_EXTSN + 12
1 com.apple.CoreFoundation 0x97154808 __CFSocketManager + 764
Thread 11:
4 com.apple.DesktopServices 0x953cde34 TPropertyTask::PropertyTaskProc(void*) + 100
Thread 12:
Thread 13:
2 libSystem.B.dylib 0x95d15b64 mach_msg_server_once + 300
3 com.apple.QuickLookFramework 0x97eb8480 _QLThumbnailGetImageIfNecessary + 1368
4 com.apple.QuickLookFramework 0x97eb8834 QLThumbnailCopyImage + 20
5 com.apple.QuickLookFramework 0x97eb8a80 QLThumbnailImageCreate + 108
6 com.apple.AppKit 0x92b3497c -[NSNavFBENode _calculatePreviewThumbnailImageWithMaxSize:isThumbnail:] + 404
7 com.apple.AppKit 0x92b34538 +[NSNavFBENodePreviewHelper _subthreadComputePreviewThumbnailImages] + 508
8 com.apple.Foundation 0x91f4ad84 __NSThread__main__ + 1004
9 libSystem.B.dylib 0x95ce7f70 _pthread_start + 316
Thread 14:
0 libSystem.B.dylib 0x95caca88 __semwait_signal + 8
1 libSystem.B.dylib 0x95cac89c nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x95cac7cc usleep$UNIX2003 + 68
3 com.apple.AppKit 0x92970e64 -[NSUIHeartBeat _heartBeatThread:] + 1840
4 com.apple.Foundation 0x91f4ad84 __NSThread__main__ + 1004
Thread 0 crashed with PPC Thread State 32:
srr0: 0x0072f5d4 srr1: 0x0000d030 dar: 0xbf7fffe0 dsisr: 0x42000000
r0: 0x00000000 r1: 0xbf800040 r2: 0xbf8000f0 r3: 0x0662b000
r4: 0x00000000 r5: 0x00000000 r6: 0x00000000 r7: 0x0000000a
r8: 0x0662b000 r9: 0x0072fee4 r10: 0x0000000c r11: 0x49443303
r12: 0xbf800174 r13: 0x06780e80 r14: 0xbfffd8e8 r15: 0x06783920
r16: 0x008d5274 r17: 0x00a45274 r18: 0xbfffd5d4 r19: 0xbfffd5e8
r20: 0x0741f430 r21: 0x00a45274 r22: 0xbfffd5d8 r23: 0x00000000
r24: 0x0662b000 r25: 0x06639500 r26: 0xbfffd4e8 r27: 0x008ae215
r28: 0x0663b000 r29: 0x00000000 r30: 0x00000000 r31: 0x0072f5b8
cr: 0x24044408 xer: 0x00000000 lr: 0x0072f5b8 ctr: 0x0072fee4
vrsave: 0x00000000
Binary Images:
0x1000 - 0xa47fff +Audacity ??? (???) <0c817f0b2b89d2bd96f43ca68ac8725b> /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
0x1017000 - 0x1033ffb com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1049000 - 0x106afff libexpat.1.dylib ??? (???) <e955fbf7296287c4d40694cf7dffd64f> /usr/lib/libexpat.1.dylib
0x1093000 - 0x1095ffd com.apple.textencoding.unicode 2.2 (2.2) <483d06bdf16bdbbad53efcea4fcfb688> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x10e3000 - 0x10e7ffb com.apple.CommonCocoaPanels 3.0 (15) <869fed3827c128784c297a78da77ab4a> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x1641000 - 0x1643fff +mod-script-pipe.so ??? (???) <9431706db7fc99b03d0504e9f98a1ed1> /Applications/Audacity/modules/mod-script-pipe.so
0x1649000 - 0x164dfff com.apple.audio.AudioIPCPlugIn 1.0.6 (1.0.6) <ac58ebbd8e1179ff891b7a60b2ba33cc> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1652000 - 0x1653ffd com.apple.aoa.halplugin 2.5.8 (2.5.8f1) <0d6be2c83d2f582060ba48293d283cdd> /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x1722000 - 0x1722ffa +hard_limiter_1413.so ??? (???) <01090df88db656e355ed214d2df7a73e> /Applications/Audacity/plug-ins/hard_limiter_1413.so
0x60f9000 - 0x60fdff4 +gverb_1216.so ??? (???) <2cb28f692521a446fc792d35022796ba> /Applications/Audacity/plug-ins/gverb_1216.so
0x6100000 - 0x6102ff4 +sc4_1882.so ??? (???) <f9657b7606ff9c887642904c1d75de5a> /Applications/Audacity/plug-ins/sc4_1882.so
0x6ac0000 - 0x6ca7ff3 com.apple.RawCamera.bundle 2.1.3 (537) <d485a6c33b017f6535c72b77ff4a8a84> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x73b9000 - 0x73c3ff7 +libavutil.50.dylib ??? (???) <d329f89206d875747f2bb77fe6be8714> /usr/local/lib/audacity/libavutil.50.dylib
0x7564000 - 0x75f3ff7 +libavformat.52.dylib ??? (???) <62b1be0b58cab03a555752b5d17ff536> /usr/local/lib/audacity/libavformat.52.dylib
0x7700000 - 0x7b57ffb +libavcodec.52.dylib ??? (???) <23e5ccbb64cc93678bc5161071454b8f> /usr/local/lib/audacity/libavcodec.52.dylib
0x8004000 - 0x8010ffe com.apple.URLMount 3.1.1 (3.1.1) <ce72e6d656560960643613ba017360c1> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0x8087000 - 0x808dfff libCGXCoreImage.A.dylib ??? (???) <16eb24800b7e310f46fdf65e3dba73c4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x70000000 - 0x700cdff3 com.apple.audio.units.Components 1.5.2 (1.5.2) /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe30c23 dyld 97.1 (???) <89a0055b0e7ea2db881b73c6e63bc774> /usr/lib/dyld
0x90003000 - 0x901ecffb com.apple.security 5.0.7 (1) <2c8ae7414f8d113a695da92950753ad9> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x901ed000 - 0x901f6fff com.apple.DiskArbitration 2.2.1 (2.2.1) <682f5c45591e8c4a89c79e384e2c49af> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x901f7000 - 0x9023efff com.apple.NavigationServices 3.5.2 (163) <453fd79dd63debad4908dcc726f9aa04> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x902d3000 - 0x9060afff com.apple.QuickTime 7.7 (1680.28) <65ceb1f7d99bc1a7873257d36b092aa3> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9060b000 - 0x90622ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x90623000 - 0x90623ff8 com.apple.Cocoa 6.5 (???) <e9a4f1c636d00893db0494c4040176ba> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x90624000 - 0x9074eff1 com.apple.WebKit 5534 (5534.50.2) <8307eb3b6a885d49844034bef76f983e> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9074f000 - 0x9079efff com.apple.Metadata 10.5.8 (398.26) <1a261534027b9d1518327d1fabe1182b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9079f000 - 0x907aaff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x907b2000 - 0x907bffff libCSync.A.dylib ??? (???) <02b13948e78cc30bd9f122a024ed9e17> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x907c0000 - 0x917bd375 com.apple.WebCore 5534 (5534.50.1) <0acf516306fd6327a76613c1f0dfdbe7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x917be000 - 0x918a8fff libxml2.2.dylib ??? (???) <9d05a5451084c8cd78e3f4722e2c2960> /usr/lib/libxml2.2.dylib
0x918af000 - 0x91934fff libsqlite3.0.dylib ??? (???) <daf55b073488086ef5b9a3781be53f14> /usr/lib/libsqlite3.0.dylib
0x91974000 - 0x91ef0ff3 com.apple.CoreGraphics 1.409.8 (???) <e0bf5ff8fa51b99663fcb860bf44a7ed> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x91ef1000 - 0x91f40fff libGLImage.dylib ??? (???) <2e1f2a2625064149d209ec19e52d0384> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x91f41000 - 0x92187ffb com.apple.Foundation 6.5.9 (677.26) <c30e4aea51bbae480d4550cd53abb441> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x922d7000 - 0x92359fff com.apple.print.framework.PrintCore 5.5.4 (245.6) <3cde2550ec10348b7162d2b6cb0dfc67> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9235a000 - 0x9235affb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x9235b000 - 0x923f4fc3 libvDSP.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x92406000 - 0x92407fff libffi.dylib ??? (???) <11b77dbce4aa0f0b66d40014230abd1d> /usr/lib/libffi.dylib
0x92408000 - 0x92420ffb com.apple.DictionaryServices 1.0.0 (1.0.0) <fe37191e732eeb66189185cd000a210b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x92421000 - 0x92428fff com.apple.CommonPanels 1.2.4 (85) <0d1256175c5512c911ede094d767acfe> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92429000 - 0x924c0fff com.apple.LaunchServices 292 (292) <06cb373fd960fbc2b4a0201f55c7dd6d> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x924c1000 - 0x924c1ffa com.apple.CoreServices 32 (32) <42b6dda539f7411606187335d9eae0c5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x924c2000 - 0x924ceff3 com.apple.audio.SoundManager 3.9.2 (3.9.2) <79588842bcaf6c747a95b2120304397a> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x924cf000 - 0x925e3ffa com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x925e4000 - 0x925f3fff com.apple.DSObjCWrappers.Framework 1.3 (1.3) <305892aafaceb4e31915f0d759ef7e6d> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x925f4000 - 0x925f4ffe com.apple.quartzframework 1.5 (1.5) <1477ba992c53f43087c7527c4782fd54> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x925f5000 - 0x92603fff libz.1.dylib ??? (???) <1a70dd3594a8c5ad39d785af5da23237> /usr/lib/libz.1.dylib
0x92604000 - 0x92611fff libbz2.1.0.dylib ??? (???) <e25cbe0b7e3f3ff41ace9428e57e304c> /usr/lib/libbz2.1.0.dylib
0x92612000 - 0x92612fff com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x92613000 - 0x92618ff6 libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x92619000 - 0x92760ffb com.apple.audio.toolbox.AudioToolbox 1.5.3 (1.5.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92765000 - 0x9276cffb com.apple.print.framework.Print 218.0.3 (220.2) <021d2263007c538fd9e6b52e66a2623d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x927b2000 - 0x927b2fff com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x927de000 - 0x927ecff3 com.apple.opengl 1.5.10 (1.5.10) <54bae289e544387ce7997a4a05e70aa9> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x927ed000 - 0x9284fffb com.apple.htmlrendering 68 (1.1.3) <e852db1c007de975fae2f0c2769c88ef> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92850000 - 0x928d8ffb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <6fc8a8cb43506b57b951da899a55d3b9> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x928d9000 - 0x9304ffff com.apple.AppKit 6.5.9 (949.54) <687f1742c249d7c9268e2eb57713cef6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93050000 - 0x93053ffb com.apple.securityhi 3.0 (30817) <e50c0cac9048f8923b95797753d50b5c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93054000 - 0x93067fff com.apple.LangAnalysis 1.6.5 (1.6.5) <2a661ad6e432dd62dd831e234904061f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x931d5000 - 0x93213fff com.apple.CoreMedia 0.484.2 (484.2) <7f4e63a5cfeaa09a9f5cb0f36e0d86f4> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x93259000 - 0x93281fff libxslt.1.dylib ??? (???) <82421418f81b9b6c63529215a3612ab0> /usr/lib/libxslt.1.dylib
0x93282000 - 0x9383cfff libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9383d000 - 0x93840fff com.apple.help 1.1 (36) <7106d6e074a3b9835ebf1e6cc6c822ce> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x938e4000 - 0x93a85ff7 com.apple.QuartzComposer 2.1 (106.13) <6dd1df71cb588b1b9ceb0c5bbf32e842> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x93ab8000 - 0x93ca8ff3 com.apple.JavaScriptCore 5534 (5534.49) <85d598f60ce2169c99f4aab053b8f0c0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x93ca9000 - 0x93cc8fff com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x93d99000 - 0x93dc4ff7 libauto.dylib ??? (???) <a64d088b2d17e013b9ee5a08d3a20d33> /usr/lib/libauto.dylib
0x93dc5000 - 0x93df2fff libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x93df3000 - 0x93ea6ffc com.apple.CFNetwork 438.16 (438.16) <a5b69f31ef4596c8f680772120e3eb08> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93fe2000 - 0x94013fff com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x94014000 - 0x94159fff com.apple.QTKit 7.7 (1680.28) <82f2e52d651c3ac3acb1136ea42a36d1> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9415a000 - 0x941f4ff7 com.apple.ApplicationServices.ATS 3.8 (???) <68fbf8a95392317d611f00c709955c8a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x941f5000 - 0x94236ffb libTIFF.dylib ??? (???) <6910f0c75ed82f98ea8ebf601136ce47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94237000 - 0x9423bffe libGIF.dylib ??? (???) <e4f0002b104c2a2cb5b4327e906e544f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9423c000 - 0x9425dffb com.apple.AppleVAFramework 4.1.17 (4.1.17) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x94269000 - 0x94288fff com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x94289000 - 0x945eeffe com.apple.QuartzCore 1.5.8 (1.5.8) <60e54cfb861dc5e66bb4f263a192d558> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x945ef000 - 0x945f5fff com.apple.DisplayServicesFW 2.0.2 (2.0.2) <7f4de3ca234fdf3f06f25d47d7119e9b> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x945f6000 - 0x946a6fff com.apple.QD 3.11.57 (???) <e74b370c6f81fc00e8936f5cf7c8ebe0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x946a7000 - 0x94777ff7 com.apple.ColorSync 4.5.4 (4.5.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x94778000 - 0x94802fff libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x94803000 - 0x94805ffd libRadiance.dylib ??? (???) <50c07ca861b00fa063aec748b5f4d786> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94812000 - 0x94831fff libresolv.9.dylib ??? (???) <c5c72e1cf61cb844163156956a1d8407> /usr/lib/libresolv.9.dylib
0x94832000 - 0x94b34ffb com.apple.CoreServices.CarbonCore 786.16 (786.16) <d9a357a3be5a1bf5969e80db6a4b3327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94deb000 - 0x94eb3ffb com.apple.CoreData 100.2 (186.2) <be912ff41bd4506438a71d5665e89069> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x94eb4000 - 0x94ef1fff libRIP.A.dylib ??? (???) <7f98bbcfc21f87ba692ae1722bc9ecd7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x94ef2000 - 0x9503efff com.apple.ImageIO.framework 2.0.9 (2.0.9) <d12782e17c25bb9679c5d352ac202fcd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9503f000 - 0x95068ffb com.apple.shortcut 1.0.1 (1.0) <8da20d176ab4cf71cdf4f79b477fe0e7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x950a7000 - 0x950a7ffc com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <91aadd6dccda219dd50a6ce06aad5b54> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x950a8000 - 0x950c3ff3 com.apple.DirectoryService.Framework 3.5.7 (3.5.7) <af876670c51c87b1cb4da0926f02540d> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x950c4000 - 0x950ccfff libbsm.dylib ??? (???) <c1fca3cbe3b1c21e9b31bc89b920f34c> /usr/lib/libbsm.dylib
0x950cd000 - 0x95187fff libcrypto.0.9.7.dylib ??? (???) <1d82e65c85d65367f3b6b06355c89c9b> /usr/lib/libcrypto.0.9.7.dylib
0x95188000 - 0x95189ff8 com.apple.ApplicationServices 34 (34) <6aa5ee485bb2e656531b3505932b845f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x951f7000 - 0x9521efff libcups.2.dylib ??? (???) <8b27a8d2477e9b253a664ad72ebc6ae5> /usr/lib/libcups.2.dylib
0x9521f000 - 0x95367ff3 libicucore.A.dylib ??? (???) <bdab570d90979c4f601131d442f84720> /usr/lib/libicucore.A.dylib
0x95368000 - 0x95373fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <ae3dc890a43a9269388301f6b59d3091> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95374000 - 0x953adfff com.apple.SystemConfiguration 1.9.2 (1.9.2) <21dee7ffd93306032f911b5ef3fdbab3> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x953ae000 - 0x953b9ffb libgcc_s.1.dylib ??? (???) <ea47fd375407f162c76d14d64ba246cd> /usr/lib/libgcc_s.1.dylib
0x953ba000 - 0x95449fff com.apple.DesktopServices 1.4.9 (1.4.9) <07d08e199716420b6df8e23ff91b5d2d> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9544a000 - 0x955b5ffb com.apple.MediaToolbox 0.484.2 (484.2) <d6f38672c014b3e26eedb9f507c7d28f> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x95779000 - 0x957bbfff com.apple.quartzfilters 1.5.0 (1.5.0) <3f2dc01a646cd5b5ea55d510583ba4d5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x957bc000 - 0x95af5ff7 com.apple.HIToolbox 1.5.6 (???) <a3b713a77c16da495c886463985f1e39> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x95af6000 - 0x95af6fff com.apple.Carbon 136 (136) <6a6a209ec9179368db7ead8382b8ee63> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x95bc8000 - 0x95bdbffb com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <050180a659a3905ea38f2acddcdf7b40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x95c23000 - 0x95c84fff com.apple.CoreText 2.0.5 (???) <0a3d84caa94b9d338921e464780dd350> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x95c85000 - 0x95ca4ffb com.apple.CoreVideo 1.6.1 (48.6) <d36e92cc8e996032d0dba765b33df82e> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x95ca5000 - 0x95e45fe3 libSystem.B.dylib ??? (???) <7dc28e19e1aac16b29cbd7c5d9ce9638> /usr/lib/libSystem.B.dylib
0x95e46000 - 0x95e90fff com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x95ef7000 - 0x95fa7fff edu.mit.Kerberos 6.0.15 (6.0.15) <870d4f0c841af131a04737468ba803d6> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x95fa8000 - 0x960cdffb com.apple.imageKit 1.0.2 (1.0) <50dfcbe41b384bd71761c761c3fbfd5e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x960ce000 - 0x96135ffb libstdc++.6.dylib ??? (???) <a4e9b10268b3ffac26d0296499b24e8e> /usr/lib/libstdc++.6.dylib
0x96ca4000 - 0x96d39ff7 com.apple.framework.IOKit 1.5.2 (???) <ced0a498252f76a2d2ba9f2a0ae02160> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x96d3a000 - 0x96e1dfff libobjc.A.dylib ??? (???) <a1d4be2eed463c6799b6a1447fde72ba> /usr/lib/libobjc.A.dylib
0x96e1e000 - 0x96e53fff com.apple.AE 402.3 (402.3) <75725936d014fd3ca2553d18b784b99b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x96e54000 - 0x96eb1ffb com.apple.HIServices 1.7.1 (???) <a6c5c0bf2d68aeb453dbc493b7d0c8d9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x96edc000 - 0x970dffff com.apple.VideoToolbox 0.484.2 (484.2) <88269569e6ac33cde858d819beea9b52> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x970e0000 - 0x97205ff3 com.apple.CoreFoundation 6.5.7 (476.19) <dee0f0024f3bf976cfa0a0816e8aa338> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x97206000 - 0x97281fff com.apple.SearchKit 1.2.2 (1.2.2) <a9d0033a5e1e55b5e382e52fe578d734> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x97282000 - 0x976b0ffe libGLProgrammability.dylib ??? (???) <5d52750ec9e438b25d3a4db51361fa2b> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x976b1000 - 0x976d1ff7 libJPEG.dylib ??? (???) <3508b46417ed11d88ae1cea92c7fe756> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x976d2000 - 0x9773effb com.apple.iLifeMediaBrowser 2.1.5 (368) <b0b43e4537e6fc11faf3eaab3a821112> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x9773f000 - 0x9775bffb com.apple.openscripting 1.2.8 (???) <01f86cdb8f7347d2f3f13066e954acb6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9775c000 - 0x977c6fff com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x977c7000 - 0x9781dfff libGLU.dylib ??? (???) <3418ce7ca0863162847f553c15d08674> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9783a000 - 0x9790dfff com.apple.CoreServices.OSServices 228.1 (228.1) <b957e9c8b8ca9c3e03b99d2ad4b31aa2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9790e000 - 0x97996fff com.apple.ink.framework 101.3 (86) <66a99ad6bc695390a66dd24789e23dcc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x97997000 - 0x9799fffb libCGATS.A.dylib ??? (???) <4766ee761032d31b0ad1855ec396e155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x979ef000 - 0x97a0affb libPng.dylib ??? (???) <7ba22147e900d2ee6837c2f439302f7f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x97a0f000 - 0x97d38fe7 libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x97d39000 - 0x97d88fff com.apple.CoreMediaIOServices 140.0 (1492) <de66669d48303ee73db4afc4ac1b630e> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x97dbf000 - 0x97eb5ffc libiconv.2.dylib ??? (???) <05ae1fcc97404173b2f9caef8f8be797> /usr/lib/libiconv.2.dylib
0x97eb6000 - 0x97ed4fff com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0xfffec000 - 0xfffeffff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff8000 - 0xffff9703 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
audacity_replaced.txt (4.83 KB)
Open one of the files in QuickTime Player and Command-I Info. What does that say?
I don’t know which stat you’re looking for, and I can’t select the text in the Inspector window in one fell swoop, so here are screen shots of the info for both files:
We have a very deep mystery here.
I can import your MP3 just fine on my Intel iMac. On my G5 Dual 2 GHz machine I can import MP3s just fine using Audacity 2.0.0. I’m downloading one of your MP3s onto my G5 and will try it there too.
Have you set any rules in Preferences > Extended Import? http://manual.audacityteam.org/man/Extended_Import_Preferences
– Bill
Confirmation! One of your MP3s crashes Audacity 2.0.0 on my G5 with exactly the same crash log. Other MP3s continue to import fine.
For the time being I’d recommend using Max http://sbooth.org/Max/ to convert the MP3s from the Sony device to some other format before importing into Audacity.
– Bill
May 9, 2012, 12:07am
15
Lucky that you have a G5 Bill.
For your information, I tried the files on Linux and no problem.
The same MP3 that crashes 2.0.0 imports fine with 1.3.14-beta Dec 9 2011 on my G5. So it appears something changed with 2.0.0 that only affects PPC import of some MP3s.
– Bill
Thanks, Bill. I have seen one other report of crashes importing MP3 files where those “guess_file_type” errors occur. He was on OS X 10.4.11 so quite likely PPC Mac, but I don’t know.
Was it the MP3 encoded by the Sony Recorder (the larger one) that crashed your G5?
@alterbentzion : have you tried installing FFmpeg then use File > Import > Audio in Audacity and choose “FFmpeg-compatible files”. This will use a different importer to import the files.
I still have the G5s that were taken out of service when we upgraded to the Intel Macs for video editing. At least one of them is still connected to a network and KVM. If this problem is still around on Thursday, I can be a check tester. I’m out of the shop on Wednesday. Koz
Yes, it was “Levaya_H_Pollock_orig.mp3”. Looking at the file with HexFiend is has “SONY IC RECORDER MP3 1.0.1” in the header.
– Bill
