Hi everybody, I can’t find the Limiter in Audacity 3.3.3 (german version), thanks a lot for your help!
Use LoudMax, it’s perfect and easy.
Hi Peter,
thanks a lot! There it should be, but in my version it doesn’t appear there. I found it now under “Erweiterungsverwaltung”, clicked it, and it appears now under “effects” → “Steve Daulton” (whoever that is) ![]()
Steve Daulton used (like me) to be a member of the old Audacity Team, As well as working here on the Forum which he still does he wrote a lot of the Nyquist plugins (which probably includes the Limiter).
You shouldn’t be seeing that Limiter effect there - try a Reset Configuration from the Tools menu:
But note that will remove any custom shortcuts you may have. If you de export those first and then re-import them after the reset.
Peter
