Bug Report: TCP Volume & Pan Popup Dialogs in macOS
@Tantacrul
I came across an issue with the TCP Volume and Pan double-click popup dialogs. Depending on platform and version of OS, entering a value in the popup dialog and either clicking OK or typing Enter dismisses the dialog, but may or may not change the value of the related control. Windows and Linux do not appear to be affected. Here are my test results:
OS Audacity Results
macOS Tahoe 26.2 3.7.7 Volume & Pan both work sporadically with OK or Enter
macOS Tahoe 26.2 2.4.2 Volume & Pan both work sporadically with OK or Enter
macOS Sequoia 15.7.3 3.7.7 Volume & Pan work as expected with OK and Enter
macOS Sequoia 15.7.3 2.4.2 Volume & Pan work as expected with OK and Enter
macOS Ventura 13.7.8 3.7.7 Volume & Pan both work sporadically with OK or Enter
macOS Ventura 13.7.8 2.4.2 Volume & Pan both work sporadically with OK or Enter
macOS Catalina 10.15.7 2.4.2 Volume & Pan work as expected with OK and Enter
Windows 11 10.0.26200 3.7.7 Volume & Pan work as expected with OK and Enter
Linux Mint 22.3 3.7.7 Volume & Pan work as expected with OK and Enter
Related Consistency Note: The OK and Cancel buttons in the Volume and Pan dialog in macOS and Linux (Cancel on the left) are reversed from their positions in Windows (OK on the left).
Hope this helps,
  • Stuart
@teetow does this need logging on GitHub ?
Logged here:
Thanks Johan,
Peter
