Hi, I’m new to audio editing and just installed Audacity.
When I try to move a track horizontally to play the sound at the right moment (similar to adjusting video in After Effects), I notice the waveform changes. I suspect it might be because I’m using the Envelope tool. I read that using the ‘Multi-Tool’ would let me grab both the envelope points and the audio itself, so I tried that. However, the waveform still changes as I move the track.
Can someone help me figure out how to position the audio at the exact time I want? Thanks!
Mac M1 14.6
Audacity 3.6.1
There’s a gear symbol on the left.
Try de-selecting Scroll View.
Thanks for your reply!
But the problem is still happening.
https://imgur.com/a/CdSeLvY
I can’t sort what we’re looking at. Is this a magnified portion of the timeline and we’re scrolling back and forth in the magnified window?
Why are there no waveforms on the timeline in the background?
@stickytape
This is a known and logged bug that is aleady fixed for the upcoming 3.6.2 release.
opened 08:24AM - 20 Jul 24 UTC
closed 10:46PM - 27 Jul 24 UTC
bug
P2
regression
Clips
### Bug description
When an Envelope is applied to a clip that starts after z… ero, the affect on the waveform is incorrectly offset.
### Steps to reproduce
1. Generate a 10 second tone
2. Apply a non-destructive fade-in to the first 2 seconds using the Envelope tool.
3. Slide the clip to the right so that it starts at time = 5 seconds
### Expected behavior
The fade is expected to remain in the same place relative to the clip.
### Actual behavior
The fade appears to have stretched to the right, even though the Envelope control points are still in the correct places relative to the clip.
Image copied from bug report on the forum:
### Audacity Version
3.6.0 / Audacity 3.7.0-alpha
### Operating system
Linux, Windows, MacSO
### Additional context
Originally reported on the forum: https://forum.audacityteam.org/t/envelope-help-what-am-i-doing-wrong/112247
Confirmed on Linux.
This is a serious bug that also affects existing projects created in previous versions.
Peter
system
Closed
September 2, 2024, 10:18pm
6
