In which case I’d install it to a separate folder - as a QA tester I have many many folders with Audacity versions (going all the way back to 0.8 and 0.98b).
All work fine - but only one instance can be run at a time - so only one version at a time.
Ok, it’s installed in Audacity 2.1.3´ folder. Also copied the lame_enc.dll file into Plug-Ins´ and made a folder `ffmpeg´ and populated that from the Zip. Seems the custom hotkeys are working just fine. Looks like it’s all set to go.
In a few days or weeks, I’d like to Uninstall 2.1.2 with alpha components (not beta) and Reinstall official 2.1.2 release.
Question: Just reinstall 2.1.2 in the original folder and forget about uninstalling? what about custom settings?
Your settings are in Users<username>\AppData\Roaming\Audacity\audacity.cfg. Those settings don’t change unless you delete audacity.cfg or reinstall Audacity with “Reset Preferences” enabled.
There is no need to uninstall before installing into the same folder.
I have 2.1.2 in **Program Files (x86)** \ **Audacity**´ folder with 2.1.3 alpha files.. and now running 2.1.3 out of Program Files (x86) \ Audacity 2.1.3´ folder.
If you want to keep both 2.1.3 release and 2.1.2 release for now, I would clean up that 2.1.2 folder by installing 2.1.2 into it: http://www.oldfoss.com/Audacity.html.
