I have Audacity 2.3.2
Audacity sees the mp3 lame library. I have downloaded ffmpeg; I have created a folder in c: even if Audacity is in c:/programmes (lame was put in c:programmes). When I do command prompt and write ffmpeg -version, the files show up.
When I go in preferences, the message is: ffmpeg library is absent. locate avformat-55. I have downloaded avformat and put it in ffmpeg/bin.
So when audacity tries to locate avformat, I write c:/ffmpeg/bin. I then validate, close Audacity, reopen it and ffmpeg is still not found.
I recommend that you follow the instructions on [u]this page[/u] to download and run [u]Lame_v3.99.3_for_Windows.exe[/u] which will install the special Audacity-version of FFmpeg
EDIT
Oops… This is an old post, but that was totally wrong!!! Download and install [u]ffmpeg-win-2.2.2.exe[/u]
LAME is already bundled-in Audacity in 2.3.2 - and it’s for MP3 export.
You need to install the FFmpeg from that download page.
avformat-55.dll
On download and extraction and installation of Lame… There is no accompanying avformat-55.dll file. So there is an issue!
Thanks Mr…Bee
avformat-55.dll has nothing to do with LAME.
avformat-55.dll is part of FFmpeg.
Good point Ta!
If you’re still experiencing this issue, make sure to download the latest version of Audacity and follow the instructions on Installing FFmpeg - Audacity Support
