reset config does not help
I changed some of the toolbars around in 3.2.5 (win 11) and now they won’t reset to original size.
View > Toolbars > Reset Toobars
Reset toolbars does not do it either.
How did you do that anyway? ![]()
You can delete audacity.cfg held in the C:\Users\yourname\AppData\Roaming\audacity directory (shortcut: “%appdata%\audacity” (I usually just rename the file to audacity-old.cfg).
Just renamed audacity.cfg file and it still has no effect.
Now I have uninstalled Audacity, restarted pc and installed it again. Still no change.!
So I am at a loss. Perhaps @LWinterberg may have some thoughts.
Did you change something with the HiDPI settings in Windows?
No. Within Audacity all I did was move some of the toolbars around. Later I tried to revert to the original layout and noticed the two buttons were different sizes.
Have checked and text size was 134%. Reduced it to 110% and that fixed it. Thank you.
Yeah, these buttons are very sensitive to HiDPI and font scaling and misbehave easily. Setting scaling options to 100% where possible or close to it generally fixes things.
This is technically a bug, but then, the entirety of HiDPI is not very well supported at all. This won’t get fixed in the current UI framework, and won’t be a problem in the one we’re moving towards for Audacity 4.
