Hello all. I am running Audacity 2.3.0 on a Mac Pro (2018) with Mojave OSx 10.14.2. I’ve tried using a Focusrite Scarlet 2i4 and directly connecting an ATR2100 USB mic. Both input devices are detected by Audacity and show up in the devices drop downs. No matter what I try, Audacity will not record or monitor any input. The built-in mic works. And the USB outputs work (I can direct Audacity output to my Focusrite or the headphone output on my ATR2100).
Also, both input devices work just fine when using GarageBand.
Right now I am stuck recording tracks on GarageBand, exporting to WAV and importing to Audacity.
Any ideas?
Thanks in advance for your help.
-Tim
Do you get any error messages?
Koz,
Thanks for responding.
No errors that were evident. I checked the diagnostics logs.
Another point of note is that on the Audacity GUI, the mic level slider is pegged all the way to the right and is not moveable.
Here is the output from the Diagnostics->Audio Devices…
Default recording device number: 1
Default playback device number: 2
Device ID: 0
Device name: Scarlett 2i4 USB
Host name: Core Audio
Recording channels: 2
Playback channels: 4
Low Recording Latency: 0.01
Low Playback Latency: 0.00351474
High Recording Latency: 0.1
High Playback Latency: 0.00875283
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
I met the same problem
Default recording device number: 0
Default playback device number: 1
Device ID: 0
Device name: MacBook Pro Microphone
Recording channels: 1
Playback channels: 0
Low Recording Latency: 0.0444792
Low Playback Latency: 0.01
High Recording Latency: 0.0538125
High Playback Latency: 0.1
Supported Rates:
Device ID: 1
Device name: MacBook Pro Speakers
Recording channels: 0
Playback channels: 2
Low Playback Latency: 0.00972917
High Playback Latency: 0.0190625
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Selected recording device: 0 - MacBook Pro Microphone
Selected playback device: 1 - MacBook Pro Speakers
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available recording sources:
Available playback volumes:
0 - PCM
Recording volume is native
Playback volume is native
January 28, 2019, 9:49am
5
Thank you very much, it works now.
