So in the new update 3.6.1, there is a new interface in a long time. In another older version (i dont remember), i had my wave color yellow and dark theme. Is there a way to bring back this without modifications of the code or something like that? thanks! oh and no i wasnt hallucinating, you can check my yt (Axim Nitro) and check “Medic Remaster Sneak Peak”. I tell you it was yellow. thanks!
Thanks, but I only want Yellow wave color. I Don’t want any installation of themes or something like that, I only want Yellow wave color. there is already blue, red, green and black, but not yellow.
The wave colors are defined as part of the theme, so you’ll need to install a theme.
you sure there is no way to get yellow back without themes?
You could theoretically go into the code and uncouple the waveform color from the theme… but that’d be even more involved than just placing a PNG into a folder.
ok, i got it. thanks!
omg, i have my yellow back! so much thanks you!!!
before you go, quick question. pre 3.6 had like darker tones of color near the top and bottom of channels. is there a way to bring this back too?
View → Show RMS
thats the audacity i know and love. thanks alot!
