Official classic & dark theme of pre-3.6 Audacity as custom theme
Old dark theme: classicTheme/Dark/ImageCache.png at main · LWinterberg/classicTheme · GitHub
Old classic theme: classicTheme/Classic/ImageCache.png at main · LWinterberg/classicTheme · GitHub
Note: These are only themes, ie the only thing they define are colors and button images. 3.6 also rearranged some buttons, which the theme cannot affect. As such, these themes don’t look identical (and only similar) to what you’d see in 3.5 and older.
See also: Installation instructions
I thank you very much for that.
I had requested it in another Thread. :+1:
went looking exactly for this, thank you.
Is there a way to bring back the lighter middle color? The contrast helped differentiating sections in the waveform '^^
View → Show RMS
Thank you very much! Now I at least know, what I should do. ))))))))) But there’s still one bug left - audacity does select all, when I open an associated file, I’ve already written the topic.
I downloaded audacity version 6.3.1. Old classic theme finally returned, thank you! But audacity still does “select all” immediately after importing. It selects the entire track, as if I clicked Select all, though I didn’t give any command, it makes me remove selection before I start a work. There was no such problem before. Why do so, hate it, please, correct!
Thanks much …
