Hi, a weird thing happened leading me to believe I accidentally changed a setting.
Usually when you highlight an area of audio, Audacity will only play your highlighted section. Today when I went to edit, I notice when I highlight an area and then listen to it, Audacity keeps playing past the highlighted area. Anyone know what I need to do to get this back to normal? (See screenshot)
Works for me on W10 with 3.7.3 (and on the latest beta test build for the upcoming 3.7.4)
Which Audacity version are you using?
I can tell from your screenshot that you are using an older version of Audacity - but I can’t tell which particular version.
I seem to recall that there may have been an earlier version where this bug occurred but I can’t find that right now.
Peter.
Same here. Closing the app and reopening it seems to work for me, but after a while it reoccurs. Definitely a glitch. I’m using the latest version.
