Hi gurus. My typically very trusty Audacity has started acting up on me today. I have re-installed a couple times to no avail, but regarding that… but do I need to buy a good uninstaller to completely remove first? Or should it work when I run Audacity installer again and replace the existing file?
When I try to open I get:
Audacity cannot be opened because of a problem. Check with the developer to make sure Audacity works with this version of macOS. You may need to reinstall the application. Be sure to install any available updates for the application and macOS.
Click Report to see more detailed information and send a report to Apple.
I am Running High Sierra 10.13.6 on a 2011 MB Pro. Model: MacBookPro8,1, BootROM 87.0.0.0.0, 2 processors, Intel Core i5, 2.3 GHz, 8 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD,
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD,
This is what the report to apple that generates says:
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x2] Wrong architecture
Application Specific Information:
dyld: launch, loading dependent libraries
DYLD_FALLBACK_LIBRARY_PATH=::/Users/user/lib:/usr/local/lib:/usr/lib
DYLD_LIBRARY_PATH=
Dyld Error Message:
Library not loaded: /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
Referenced from: /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
Reason: no suitable image found. Did find:
/System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice: mach-o, but wrong architecture
/System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice: stat() failed with errno=45
Thanks so much in advance for any words of wisdom!!
Jeremiah
