Audacity 4/Mac OS 26.1 Playhead Jumps, and issues with Selecting and Moving Clips
I might be crazy, but I’m trying to work with a 3-hour project (that may be relevant, not sure…)
What I am doing is replacing sections of a 40 year old off-air recording with clean versions. So, I’ll be removing chunks and lining up replacements in a separate track.
When I grab a clip to move around, it moves the playhead and timeline focus to the beginning of the clip selected (when you’re zoomed in, trying to match sounds, that’s like a million miles away).
Similarly, clicking onto the time line does not always guarantee that playback will start where clicked, and not jump back to the beginning of the file (again, it’s a long file).
One more funky clip issue, but I don’t know what triggers it. Sometimes I’ll grab a clip to move, and another clip will disappear. May have to do with the ability to overwrite a clip (or portion of) with another – though I never placed the clip on the one disappearing.
ETA (11/1/25): I forgot about when splitting a clip, the timeline focus jumps to the beginning of the new left-side clip, instead of staying where the split was made (which would be the head of the new right-side clip)
Are you really using Audacity v4 for this project or are you really using 3.7.5 or earlier (you posted in the Audacity 4 section of the Forum)?
If you are using v4 then this is a very early pre-release test version, only the second alpha test build that Muse have made available for folk to test and report issues - and certainly NOT for live projects.
Peter.
Well, yes I am using the Alpha. How else would one test and report issues if not by using the software. Plus, I have a few weeks before I need to have the file done…
I can’t help you with version 4 - but I’d do the project in a final version and then test the same thing with an alpha version. This is for sure better for your mental health than the other way… :grinning_face:
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
