The new compressor and limiter were a terrible idea as a replacement. They can be useful but have broke many people’s presets and have lost several functions of the old ones. It is an absolute deal breaker for me. Rolling back and staying put with an older version and just have to hope it gets straightened out.
I am afraid that I, too, have rolled back due to the issues with compressor and limiter and the number of crashes I am encountering. Time to wait for a more stable issue
Audacity’s latest version when the PC black screen a crash log comes up. It royally pissed me off because I left my Heritage Chart to record during the Sport and it crash logged to the black screen instead of kept going like it should do.
Why did you let this unstable beta version to be released guys. I now could be waiting for days for the good Heritage Charts own Mixcloud version or have to get a stepdown in sound quality on distorted Regency Radio because Legacy Chart is now on Pay Per Catch-Up.
Sorry if I seem annoyed but that was because I am annoyed at this rubbish version. As soon as screen saver came on crash log no carrying on.
I want to leave it and then it staying on like the behavior of the software normally on a long show.
This version should have never have been allowed without testing it on leaving it to record for 2 hours without touhing the mouse with no crashlogs.
It’s a legit problem as well it happened when I had left it during my daily walk just in case I miss the start.
It happened again when I did it during the sport. This shouldn’t be happening a completely unstable mess I want to revert but bet I can’t even do that because AI hiss removal has updated to 3.6.
I expect Audacity to handle a recording. Last version at least when it black screened you might get some popping or farting or even some gaps but at least it’s still running on this it’s just crash log impending recording loss of doomsday it’s completely destroyed nothing can be done about it if you don’t reach the mouse in time.
Ok the first time Norton 360 interrupted as well as the black screen sso it’s not fair to count that one as the version being dodgy.
But this one where I timed it to every 10 laps on Formula one racing and moved the mouse to be sure it wasn’t blacks screen and it was only the final set of 10 where the final lap is a bit slower that it timed out even if it was only a couple of seconds it was enough to cut off enough of the show for the footage to be useless not even worth a continue.
I’m frustrated with 3.6 proper that I had to go all out in rage and anger so it gets fixed in a single day to not crash log on a screen saver or black screen.
Ok, 3.4.0 or whatever version it was was probably the worst version ever produced total crap not loading the FFMPEG but this is a second place worst ever beta state release which shouldn’t have seen the light of day as it can’t handle screen savers coming on and if you don’t move the mouse 1 second within time you are doomed you lost your show until a very late Mixcloud and a on time but really distorted quality Regency on demand copy.
But it’s 2 dud versions in 6 months guys that’s becoming a bad track record for bad versions.
I can still make my own radio so it’s a step above 3.4.0 but I can’t record my own catchup of shows that the wait is painful for a good quality on demand on it.
A different issue and that is it worked perfect when I used the mouse all the time doing other things on Legacy Chart it only seems to be screensaver back screens and mouse locks and when you press enter for your screen back on it’s a crash log not a carrying on.
But the behaviour recording a 2 hour show seems to be correct when you are doing something which is bad when you want something to record perfectly to listen to when you are back from being busy.
Small UI question, it seems like the line for low-volume noise has gotten noticably thinner in the new version. The little bumps at 18:43.5 and 18:45.5 represent the end of trailing noise I need to eliminate, but they’re pretty hard to see; previously they were much thicker, which made my job a lot easier. Is there a setting for this?
Hey all! We just released 3.6.1 with the following fixes:
- #6889 Fixed a crash when exporting multichannel audio.
- #6882 Fixed a crash when pasting mono clips into stereo tracks.
- #4763 (Accessibility) Made more values available when using the plain UI of plugins. (Thanks, David Bailes!)
- #6855 Prevented incompatible versions from opening projects created in 3.6.x.
- #6892 Fixed the dark theme sometimes having white corners in buttons.
Thanks for the fixes. The issues I’m having with my regular use is:
As mentioned above in my comment, when Sync-Lock is on and I highlight one track, it highlights all the other tracks in the same white solid highlight so I can’t see which track is highlighted unless I remember it - the faint clocks pattern that used to appear on the other tracks is gone.
When I use Audio Clips-Join with short cut it turns the whole track back to the basic blue colour, but I use different colours for different tracks, so I have to go and change it back again, and this is taking one or two attempts because I have to select colour 1, then the colour I want, because it thinks it’s already on the colour I want. So there’s something up with the track colours.
I’m finding the little white squares harder to grab when adjusting the levels using the multi-tool, have to zoom right in.
Not sure if it’s me, but I used to use the limiter to lop off the excessively high bits of audio, now when I use that it makes the whole track a lot louder.
Thanks.
I Agree aswell
So a couple weeks ago I downloaded an update for Audacity and it made it so I can’t skip back tapping the arrow keys further than where the cursor, I guess it’s what you would say, is put. It has been the worst thing ever. It has added so much time to my editing. I hate it so much. I didn’t have any idea why audacity would do this. Is it fixed on the newest update?
I hate having to reset where the cursor is to be able to go back when before I could just tap the arrows to go back as far as I choose.
Agree 100%. Who thought it was a great idea to replace the compressor with one that is incompatible with the old one? By all means introduce a new one ALONGSIDE the old one, but you’ve just totally broken Audacity for me, and lost me hours of time trying (and failing) to re-create presets and macros. I think the new compressor doesn’t allow peak compression. That’s a deal-breaker for me. Reverted to 3.5.1. Hopefully sense prevails.
I’ve updated audacity 3.6.1 but it’s crashing and does not permit to use openvino!
AND IT DOES NOT SEND CRASH REPORTS!
Here’s the report that it’s not able to send:
Operating system: Windows NT
10.0.19045 4651
CPU: amd64
family 6 model 142 stepping 9
4 CPUs
GPU: UNKNOWN
Crash reason: EXCEPTION_ACCESS_VIOLATION_READ
Crash address: 0x7ff91a2e6200
Process uptime: 39 seconds
Thread 0 (crashed)
0 lib-effects.dll + 0xf695
rax = 0x0000014469c8e920 rdx = 0x0000000000000000
rcx = 0x0000014469c8e920 rbx = 0x0000014469c8e958
rsi = 0x0000000000000000 rdi = 0x0000014469c8ec20
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf870
r8 = 0x00007ff91a2e61e0 r9 = 0x0000000000000001
r10 = 0x0000000000008000 r11 = 0x00000008ecfaf7a0
r12 = 0x00007ff931551032 r13 = 0x0000000000000000
r14 = 0x00000008ecfaf998 r15 = 0x0000014467ef6a60
rip = 0x00007ff93155f695
Found by: given as instruction pointer in context
Stack contents:
00000008ecfaf870 70 e8 c8 69 44 01 00 00 00 00 00 00 00 00 00 00 pèÈiD...........
00000008ecfaf880 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfaf890 b7 b8 cb 54 6f 3e 00 00 57 ef 57 31 f9 7f 00 00 ·¸ËTo>..WïW1ù...
Possible instruction pointers:
1 lib-effects.dll + 0x2ef57
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf8a0
rip = 0x00007ff93157ef57
Found by: stack scanning
Stack contents:
00000008ecfaf8a0 88 6a ef 67 44 01 00 00 60 6a ef 67 44 01 00 00 .jïgD...`jïgD...
00000008ecfaf8b0 60 6a ef 67 44 01 00 00 5b 05 0d 63 f9 7f 00 00 `jïgD...[..cù...
2 KERNELBASE.dll + 0x6055b
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf8c0
rip = 0x00007ff9630d055b
Stack contents:
00000008ecfaf8c0 90 6a ef 67 44 01 00 00 d6 42 38 63 f9 7f 00 00 .jïgD...ÖB8cù...
3 ucrtbase.dll + 0x142d6
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf8d0
rip = 0x00007ff9633842d6
Stack contents:
00000008ecfaf8d0 9c cd 11 46 67 5a 00 00 10 e4 ef 67 44 01 00 00 Í.FgZ...äïgD...
00000008ecfaf8e0 1f 00 00 00 00 00 00 00 ae 60 38 63 f9 7f 00 00 ........®`8cù...
4 ucrtbase.dll + 0x160ae
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf8f0
rip = 0x00007ff9633860ae
Stack contents:
00000008ecfaf8f0 fe ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 þÿÿÿÿÿÿÿ........
00000008ecfaf900 01 00 00 00 00 00 00 00 00 00 55 31 f9 7f 00 00 ..........U1ù...
00000008ecfaf910 88 f9 fa ec 08 00 00 00 fb 41 38 63 f9 7f 00 00 .ùúì....ûA8cù...
5 ucrtbase.dll + 0x141fb
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf920
rip = 0x00007ff9633841fb
Stack contents:
00000008ecfaf920 00 00 00 00 00 00 00 00 98 f9 fa ec 08 00 00 00 .........ùúì....
00000008ecfaf930 70 fc fa ec 08 00 00 00 40 0e 46 63 f9 7f 00 00 püúì....@.Fcù...
6 ucrtbase.dll + 0xf0e40
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf940
rip = 0x00007ff963460e40
Stack contents:
00000008ecfaf940 01 00 00 00 00 00 00 00 b4 41 38 63 f9 7f 00 00 ........´A8cù...
7 ucrtbase.dll + 0x141b4
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf950
rip = 0x00007ff9633841b4
Stack contents:
00000008ecfaf950 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................
00000008ecfaf960 60 05 60 61 f9 7f 00 00 `.`aù...
8 windows.storage.dll + 0x720560
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf968
rip = 0x00007ff961600560
Stack contents:
00000008ecfaf968 88 f9 fa ec 08 00 00 00 00 00 00 00 00 00 00 00 .ùúì............
00000008ecfaf978 c1 74 57 31 f9 7f 00 00 ÁtW1ù...
9 lib-effects.dll + 0x274c1
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf980
rip = 0x00007ff9315774c1
Stack contents:
00000008ecfaf980 78 28 59 31 f9 7f 00 00 x(Y1ù...
10 lib-effects.dll + 0x42878
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf988
rip = 0x00007ff931592878
Stack contents:
00000008ecfaf988 02 00 00 00 f9 7f 00 00 02 00 00 00 00 00 00 00 ....ù...........
00000008ecfaf998 80 f9 fa ec 08 00 00 00 00 b6 7e 63 f9 7f 00 00 .ùúì.....¶~cù...
11 bcryptPrimitives.dll + 0x7b600
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf9a8
rip = 0x00007ff9637eb600
Stack contents:
00000008ecfaf9a8 93 99 7e 65 f9 7f 00 00 .~eù...
12 ntdll.dll + 0x19993
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf9b0
rip = 0x00007ff9657e9993
Stack contents:
00000008ecfaf9b0 00 00 00 00 00 00 00 00 fd 75 57 31 f9 7f 00 00 ........ýuW1ù...
13 lib-effects.dll + 0x275fd
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf9c0
rip = 0x00007ff9315775fd
Stack contents:
00000008ecfaf9c0 01 00 00 00 00 00 00 00 00 fc fa ec 08 00 00 00 .........üúì....
00000008ecfaf9d0 01 00 00 00 00 00 00 00 7e 8d 7a 63 f9 7f 00 00 ........~.zcù...
14 bcryptPrimitives.dll + 0x38d7e
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf9e0
rip = 0x00007ff9637a8d7e
Stack contents:
00000008ecfaf9e0 01 00 00 00 00 00 00 00 6f 22 74 62 f9 7f 00 00 ........o"tbù...
15 CRYPTBASE.DLL + 0x226f
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfaf9f0
rip = 0x00007ff96274226f
Stack contents:
00000008ecfaf9f0 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................
00000008ecfafa00 00 00 55 31 f9 7f 00 00 84 03 fe 7f 00 00 00 00 ..U1ù....þ.....
00000008ecfafa10 00 00 00 00 00 00 00 00 1d 9a 7e 65 f9 7f 00 00 .........~eù...
16 ntdll.dll + 0x19a1d
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafa20
rip = 0x00007ff9657e9a1d
Stack contents:
00000008ecfafa20 00 00 55 31 f9 7f 00 00 00 00 00 00 00 00 00 00 ..U1ù...........
00000008ecfafa30 01 00 00 00 00 00 00 00 85 03 fe 7f 00 00 00 00 ........
.þ.....
00000008ecfafa40 00 00 00 00 00 00 00 00 41 f3 82 65 f9 7f 00 00 ........Aóeù...
17 ntdll.dll + 0x5f341
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafa50
rip = 0x00007ff96582f341
Stack contents:
00000008ecfafa50 00 cc 11 46 67 5a 00 00 f0 7c e6 67 44 01 00 00 .Ì.FgZ..ð|ægD...
00000008ecfafa60 32 10 55 31 f9 7f 00 00 2.U1ù...
18 lib-effects.dll + 0x1032
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafa68
rip = 0x00007ff931551032
Stack contents:
00000008ecfafa68 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafa78 00 b0 08 ed 08 00 00 00 a0 ab e0 67 44 01 00 00 .°.í.... «àgD...
00000008ecfafa88 da f1 82 65 f9 7f 00 00 Úñeù...
19 ntdll.dll + 0x5f1da
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafa90
rip = 0x00007ff96582f1da
Stack contents:
00000008ecfafa90 c0 41 e2 67 44 01 00 00 00 00 55 31 f9 7f 00 00 ÀAâgD.....U1ù...
00000008ecfafaa0 00 00 00 00 f9 7f 00 00 00 b0 08 ed 08 00 00 00 ....ù....°.í....
00000008ecfafab0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafac0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafad0 50 00 52 00 00 00 00 00 56 2a e0 67 44 01 00 00 P.R.....V*àgD...
00000008ecfafae0 48 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 H...............
00000008ecfafaf0 00 00 00 00 00 00 00 00 b8 6c e5 67 44 01 00 00 ........¸lågD...
00000008ecfafb00 20 00 00 00 00 00 00 00 ff ff ff ff ff ff ff ff .......ÿÿÿÿÿÿÿÿ
00000008ecfafb10 47 93 1a 98 bb fe ff ff ad f1 82 65 f9 7f 00 00 G..»þÿÿñeù...
20 ntdll.dll + 0x5f1ad
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafb20
rip = 0x00007ff96582f1ad
Stack contents:
00000008ecfafb20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafb30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafb40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafb50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafb60 2c c5 11 46 67 5a 00 00 08 f6 82 65 f9 7f 00 00 ,Å.FgZ...öeù...
21 ntdll.dll + 0x5f608
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafb70
rip = 0x00007ff96582f608
Stack contents:
00000008ecfafb70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafb80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafb90 00 00 00 00 00 00 00 00 8d ef 82 65 f9 7f 00 00 .........ïeù...
22 ntdll.dll + 0x5ef8d
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafba0
rip = 0x00007ff96582ef8d
Stack contents:
00000008ecfafba0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafbb0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafbc0 00 00 00 00 00 00 00 00 eb e3 6c 65 f9 7f 00 00 ........ëãleù...
23 KERNEL32.DLL + 0x1e3eb
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafbd0
rip = 0x00007ff9656ce3eb
Stack contents:
00000008ecfafbd0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafbe0 a0 d3 42 63 f9 7f 00 00 ÓBcù...
24 ucrtbase.dll + 0xbd3a0
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafbe8
rip = 0x00007ff96342d3a0
Stack contents:
00000008ecfafbe8 70 fc fa ec 08 00 00 00 00 00 00 00 00 00 00 00 püúì............
00000008ecfafbf8 bc 05 39 63 f9 7f 00 00 ¼.9cù...
25 ucrtbase.dll + 0x205bc
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafc00
rip = 0x00007ff9633905bc
Stack contents:
00000008ecfafc00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafc10 58 fc fa ec 08 00 00 00 40 0e 46 63 f9 7f 00 00 Xüúì....@.Fcù...
26 ucrtbase.dll + 0xf0e40
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafc20
Stack contents:
00000008ecfafc20 00 00 00 00 00 00 00 00 5f 04 39 63 f9 7f 00 00 ........_.9cù...
27 ucrtbase.dll + 0x2045f
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafc30
rip = 0x00007ff96339045f
Stack contents:
00000008ecfafc30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafc40 00 00 00 00 00 00 00 00 50 fc fa ec 08 00 00 00 ........Püúì....
00000008ecfafc50 02 00 00 00 02 00 00 00 88 fc fa ec 08 00 00 00 .........üúì....
00000008ecfafc60 90 fc fa ec 08 00 00 00 98 fc fa ec 08 00 00 00 .üúì.....üúì....
00000008ecfafc70 00 00 00 00 00 00 00 00 80 0b 01 11 f6 7f 00 00 ............ö...
28 audacity.exe + 0x6a0b80
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafc80
rip = 0x00007ff611010b80
Stack contents:
00000008ecfafc80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafc90 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................
00000008ecfafca0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafcb0 00 00 00 00 00 00 00 00 74 73 6c 65 f9 7f 00 00 ........tsleù...
29 KERNEL32.DLL + 0x17374
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafcc0
rip = 0x00007ff9656c7374
Stack contents:
00000008ecfafcc0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafcd0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafce0 00 00 00 00 00 00 00 00 91 cc 81 65 f9 7f 00 00 ........Ì.eù...
30 ntdll.dll + 0x4cc91
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafcf0
rip = 0x00007ff96581cc91
Stack contents:
00000008ecfafcf0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafd00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafd10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000008ecfafd20 00 00 00 00 a1 82 52 53 00 00 00 00 00 00 00 00 ....¡RS........
00000008ecfafd30 00 00 00 00 00 00 00 00 e0 d8 19 63 f9 7f 00 00 ........àØ.cù...
31 KERNELBASE.dll + 0x12d8e0
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafd40
rip = 0x00007ff96319d8e0
Stack contents:
00000008ecfafd40 40 e9 fa ec 08 00 00 00 fc 3f 00 80 20 ad 25 98 @éúì....ü?.. %.
00000008ecfafd50 41 5a 4b 30 f9 7f 00 00 AZK0ù...
32 wxmsw313u_html_vc_x64_custom.dll + 0x65a41
rbp = 0x0000014467ef6a90 rsp = 0x00000008ecfafd58
rip = 0x00007ff9304b5a41
Loaded modules:
0x7ff610970000 - 0x7ff6116ecfff audacity.exe 3.6.1.0 (main) (WARNING: No symbols, Audacity.pdb, 32BE6C5685C948D1888E0B5A57049A801)
0x7ff90c180000 - 0x7ff90c1c5fff wdmaud.drv 10.0.19041.4355
0x7ff91a350000 - 0x7ff91a3b8fff mpg123.dll 0.0.0.0
0x7ff91a3c0000 - 0x7ff91a468fff libmp3lame.DLL 0.0.0.0
0x7ff91a470000 - 0x7ff91a4c8fff mod-mp3.dll 0.0.0.0
0x7ff91a4d0000 - 0x7ff91a52bfff mod-mp2.dll 0.0.0.0
0x7ff91a530000 - 0x7ff91a5a0fff mod-ffmpeg.dll 0.0.0.0
0x7ff91a5b0000 - 0x7ff91a6b7fff lib-cloud-audiocom.dll 0.0.0.0
0x7ff91a6c0000 - 0x7ff91a77efff mod-cloud-audiocom.dll 0.0.0.0
0x7ff91a780000 - 0x7ff91a804fff opus.dll 0.0.0.0
0x7ff91a810000 - 0x7ff91b2aefff wxmsw313u_core_vc_x64_custom.dll 3.1.3.0
0x7ff91b2b0000 - 0x7ff91b639fff wxbase313u_vc_x64_custom.dll 3.1.3.0
0x7ff91dec0000 - 0x7ff91defbfff tbbmalloc.dll 2021.2.2.0
0x7ff91e220000 - 0x7ff91e2bbfff dsound.dll 10.0.19041.4355
0x7ff91e570000 - 0x7ff91e7a5fff lib-theme-resources.dll 0.0.0.0
0x7ff91e8c0000 - 0x7ff91e928fff lib-ffmpeg-support.dll 0.0.0.0
0x7ff9218f0000 - 0x7ff921934fff mod-midi-import-export.dll 0.0.0.0
0x7ff921940000 - 0x7ff921a29fff vorbis.dll 0.0.0.0
0x7ff921a30000 - 0x7ff921adefff vorbisenc.dll 0.0.0.0
0x7ff921e80000 - 0x7ff921eb4fff mod-flac.dll 0.0.0.0
0x7ff921ec0000 - 0x7ff921f5efff libcurl.dll 7.82.0.0
0x7ff921f60000 - 0x7ff922038fff sqlite.dll 0.0.0.0
0x7ff9220a0000 - 0x7ff9220dcfff wavpackdll.dll 5.6.0.0
0x7ff9220e0000 - 0x7ff9221a2fff jpeg8.dll 8.2.2.0
0x7ff9226d0000 - 0x7ff922701fff mod-cl.dll 0.0.0.0
0x7ff922820000 - 0x7ff922856fff mod-aup.dll 0.0.0.0
0x7ff922860000 - 0x7ff92290dfff sndfile.dll 1.0.31.0
0x7ff922970000 - 0x7ff9229cefff FLAC.dll 0.0.0.0
0x7ff922ce0000 - 0x7ff922d24fff libpng16.dll 0.0.0.0
0x7ff922d40000 - 0x7ff922d7afff portaudio_x64.dll 0.0.0.0
0x7ff922d80000 - 0x7ff922db6fff libexpat.dll 2.5.0.0
0x7ff922dc0000 - 0x7ff922ea6fff wxmsw313u_aui_vc_x64_custom.dll 3.1.3.0
0x7ff923050000 - 0x7ff923098fff lib-numeric-formats.dll 0.0.0.0
0x7ff9230a0000 - 0x7ff923130fff lib-math.dll 0.0.0.0
0x7ff9239d0000 - 0x7ff923a50fff lib-project-file-io.dll 0.0.0.0
0x7ff9297f0000 - 0x7ff929805fff vorbisfile.dll 0.0.0.0
0x7ff929950000 - 0x7ff929991fff lib-time-and-pitch.dll 0.0.0.0
0x7ff9299a0000 - 0x7ff929a51fff lib-wave-track.dll 0.0.0.0
0x7ff929b90000 - 0x7ff929bd1fff lib-network-manager.dll 0.0.0.0
0x7ff92a210000 - 0x7ff92a22ffff mod-ogg.dll 0.0.0.0
0x7ff92eeb0000 - 0x7ff92eee8fff lib-realtime-effects.dll 0.0.0.0
0x7ff92ef90000 - 0x7ff92efaafff mod-mpg123.dll 0.0.0.0
0x7ff92f010000 - 0x7ff92f028fff mod-lof.dll 0.0.0.0
0x7ff92f230000 - 0x7ff92f258fff FLAC++.dll 0.0.0.0
0x7ff92fce0000 - 0x7ff92fd45fff lib-import-export.dll 0.0.0.0
0x7ff9303f0000 - 0x7ff930400fff lib-crypto.dll 0.0.0.0
0x7ff930410000 - 0x7ff93044ffff wxmsw313u_qa_vc_x64_custom.dll 3.1.3.0
0x7ff930450000 - 0x7ff930509fff wxmsw313u_html_vc_x64_custom.dll 3.1.3.0 (WARNING: No symbols, wxmsw313u_html_vc_x64_custom.pdb, 8CF357D3F0684676AFCB240E2EFD4E191)
0x7ff9311e0000 - 0x7ff93123efff lib-module-manager.dll 0.0.0.0
0x7ff931530000 - 0x7ff931543fff ogg.dll 0.0.0.0
0x7ff931550000 - 0x7ff93159ffff lib-effects.dll 0.0.0.0 (WARNING: No symbols, lib-effects.pdb, 43CC306C6BCF42F0A216A0BEEEADE84A1)
0x7ff9315e0000 - 0x7ff9315f0fff lib-concurrency.dll 0.0.0.0
0x7ff932a10000 - 0x7ff932aa4fff DUser.dll 10.0.19041.3636
0x7ff932b40000 - 0x7ff932b64fff lib-sqlite-helpers.dll 0.0.0.0
0x7ff932b70000 - 0x7ff932bc9fff lib-crashpad-configurer.dll 0.0.0.0
0x7ff932c30000 - 0x7ff932c52fff zlib1.dll 1.2.13.0
0x7ff934150000 - 0x7ff93416efff wxbase313u_xml_vc_x64_custom.dll 3.1.3.0
0x7ff934170000 - 0x7ff9341fefff lib-vst3.dll 0.0.0.0
0x7ff939b80000 - 0x7ff939b94fff lib-ipc.dll 0.0.0.0
0x7ff939cc0000 - 0x7ff939cd0fff lib-uuid.dll 0.0.0.0
0x7ff93a390000 - 0x7ff93a39cfff atlthunk.dll 10.0.19041.3636
0x7ff93b070000 - 0x7ff93b0f6fff lib-lv2.dll 0.0.0.0
0x7ff93b340000 - 0x7ff93b364fff lib-stretching-sequence.dll 0.0.0.0
0x7ff93b3a0000 - 0x7ff93b3b4fff lib-transactions.dll 0.0.0.0
0x7ff93b3c0000 - 0x7ff93b3e6fff lib-ladspa.dll 0.0.0.0
0x7ff93b3f0000 - 0x7ff93b41afff lib-fft.dll 0.0.0.0
0x7ff93b490000 - 0x7ff93b4a3fff lib-sample-track.dll 0.0.0.0
0x7ff93b4b0000 - 0x7ff93b4d5fff lib-string-utils.dll 0.0.0.0
0x7ff93b4e0000 - 0x7ff93b50afff lib-files.dll 0.0.0.0
0x7ff93b510000 - 0x7ff93b553fff lib-sentry-reporting.dll 0.0.0.0
0x7ff93b5d0000 - 0x7ff93b64efff lib-wx-wrappers.dll 0.0.0.0
0x7ff93b650000 - 0x7ff93b6c5fff lib-theme.dll 0.0.0.0
0x7ff93b6d0000 - 0x7ff93b73afff lib-shuttlegui.dll 0.0.0.0
0x7ff93b740000 - 0x7ff93b773fff lib-snapping.dll 0.0.0.0
0x7ff93b780000 - 0x7ff93b7d7fff lib-audio-io.dll 0.0.0.0
0x7ff93c090000 - 0x7ff93c0bbfff lib-time-frequency-selection.dll 0.0.0.0
0x7ff93c530000 - 0x7ff93c546fff lib-command-parameters.dll 0.0.0.0
0x7ff93c560000 - 0x7ff93c572fff lib-file-formats.dll 0.0.0.0
0x7ff93c5e0000 - 0x7ff93c61efff lib-audio-devices.dll 0.0.0.0
0x7ff93c670000 - 0x7ff93c69dfff lib-track-selection.dll 0.0.0.0
0x7ff93c6a0000 - 0x7ff93c72cfff MSVCP140.dll 14.40.33810.0
0x7ff93d8b0000 - 0x7ff93d8d1fff lib-utility.dll 0.0.0.0
0x7ff93d8e0000 - 0x7ff93d91cfff lib-preferences.dll 0.0.0.0
0x7ff93de00000 - 0x7ff93de4bfff lib-track.dll 0.0.0.0
0x7ff93e1a0000 - 0x7ff93e1c3fff lib-registries.dll 0.0.0.0
0x7ff93e1d0000 - 0x7ff93e242fff lib-menus.dll 0.0.0.0
0x7ff93e250000 - 0x7ff93e2c9fff lib-wx-init.dll 0.0.0.0
0x7ff93e500000 - 0x7ff93e546fff lib-vst.dll 0.0.0.0
0x7ff93e970000 - 0x7ff93e990fff lib-project-history.dll 0.0.0.0
0x7ff940380000 - 0x7ff94039efff lib-tags.dll 0.0.0.0
0x7ff9403a0000 - 0x7ff9403e6fff lib-dynamic-range-processor.dll 0.0.0.0
0x7ff940910000 - 0x7ff94093dfff lib-xml.dll 0.0.0.0
0x7ff940970000 - 0x7ff9409c8fff lib-note-track.dll 0.0.0.0
0x7ff940f50000 - 0x7ff940f82fff lib-mixer.dll 0.0.0.0
0x7ff9419c0000 - 0x7ff9419e5fff lib-strings.dll 0.0.0.0
0x7ff9429b0000 - 0x7ff942c49fff COMCTL32.dll 6.10.19041.4355
0x7ff943370000 - 0x7ff9433bcfff lib-music-information-retrieval.dll 0.0.0.0
0x7ff943760000 - 0x7ff943768fff WSOCK32.dll 10.0.19041.1
0x7ff945fd0000 - 0x7ff945ffdfff lib-project.dll 0.0.0.0
0x7ff9468d0000 - 0x7ff9468f2fff lib-preference-pages.dll 0.0.0.0
0x7ff946b40000 - 0x7ff946b53fff lib-audio-graph.dll 0.0.0.0
0x7ff947980000 - 0x7ff947a23fff WINSPOOL.DRV 10.0.19041.4597
0x7ff948930000 - 0x7ff948955fff winmmbase.dll 10.0.19041.1
0x7ff9489b0000 - 0x7ff948a15fff OLEACC.dll 7.2.19041.3636
0x7ff948a20000 - 0x7ff948a26fff MSIMG32.dll 10.0.19041.3636
0x7ff94ae50000 - 0x7ff94ae6ffff lib-components.dll 0.0.0.0
0x7ff94aea0000 - 0x7ff94aeb9fff lib-url-schemes.dll 0.0.0.0
0x7ff94b420000 - 0x7ff94b436fff lib-graphics.dll 0.0.0.0
0x7ff94b570000 - 0x7ff94b583fff portmidi.dll 0.0.0.0
0x7ff94b5e0000 - 0x7ff94b5eafff midimap.dll 10.0.19041.3636
0x7ff94b860000 - 0x7ff94b886fff WINMM.dll 10.0.19041.3636
0x7ff94b9c0000 - 0x7ff94b9dafff lib-playable-track.dll 0.0.0.0
0x7ff94b9f0000 - 0x7ff94ba9bfff TextShaping.dll 0.0.0.0
0x7ff94c7c0000 - 0x7ff94c7ccfff msacm32.drv 10.0.19041.3636
0x7ff94c900000 - 0x7ff94c908fff ksuser.dll 10.0.19041.1
0x7ff94c920000 - 0x7ff94c957fff mod-pcm.dll 0.0.0.0
0x7ff94ee40000 - 0x7ff94ef38fff textinputframework.dll 10.0.19041.4651
0x7ff950990000 - 0x7ff950b10fff AUDIOSES.DLL 10.0.19041.4355
0x7ff953aa0000 - 0x7ff953ab4fff lib-basic-ui.dll 0.0.0.0
0x7ff953b70000 - 0x7ff953b95fff lib-wave-track-paint.dll 0.0.0.0
0x7ff9567b0000 - 0x7ff9567d3fff lib-viewport.dll 0.0.0.0
0x7ff9567f0000 - 0x7ff956825fff mod-opus.dll 0.0.0.0
0x7ff956a80000 - 0x7ff956a95fff lib-exceptions.dll 0.0.0.0
0x7ff956b80000 - 0x7ff956b9dfff VCRUNTIME140.dll 14.40.33810.0
0x7ff956bb0000 - 0x7ff956bccfff lib-project-rate.dll 0.0.0.0
0x7ff956cd0000 - 0x7ff956ce7fff lib-channel.dll 0.0.0.0
0x7ff956da0000 - 0x7ff956daefff lib-export-ui.dll 0.0.0.0
0x7ff956eb0000 - 0x7ff956ed7fff mod-wavpack.dll 0.0.0.0
0x7ff956f90000 - 0x7ff956f96fff MSVCP140_CODECVT_IDS.dll 14.40.33810.0
0x7ff957510000 - 0x7ff957594fff MMDevAPI.DLL 10.0.19041.4355
0x7ff958fa0000 - 0x7ff958fbdfff lib-time-track.dll 0.0.0.0
0x7ff959620000 - 0x7ff959689fff Ninput.dll 10.0.19041.4355
0x7ff9598c0000 - 0x7ff9598c9fff AVRT.dll 10.0.19041.3636
0x7ff959b70000 - 0x7ff959b7ffff lib-screen-geometry.dll 0.0.0.0
0x7ff959cb0000 - 0x7ff959cbbfff VCRUNTIME140_1.dll 14.40.33810.0
0x7ff95a0d0000 - 0x7ff95a0d9fff VERSION.dll 10.0.19041.3636
0x7ff95a580000 - 0x7ff95a5bafff dxcore.dll 10.0.19041.4474
0x7ff95a5c0000 - 0x7ff95a716fff wintypes.dll 10.0.19041.4355
0x7ff95a900000 - 0x7ff95ac5afff CoreUIComponents.dll 10.0.19041.3636
0x7ff95acb0000 - 0x7ff95accdfff MSACM32.dll 10.0.19041.1
0x7ff95beb0000 - 0x7ff95bfa1fff CoreMessaging.dll 10.0.19041.4355
0x7ff95ffe0000 - 0x7ff960195fff WindowsCodecs.dll 10.0.19041.4648
0x7ff9601f0000 - 0x7ff96028dfff UxTheme.dll 10.0.19041.4529
0x7ff9602e0000 - 0x7ff9602f3fff resourcepolicyclient.dll 10.0.19041.4355
0x7ff960ee0000 - 0x7ff96167dfff windows.storage.dll 10.0.19041.4648 (WARNING: No symbols, Windows.Storage.pdb, B492B975B133BCD8F3DBB38A59842CA91)
0x7ff961690000 - 0x7ff9616a1fff kernel.appcore.dll 10.0.19041.3758
0x7ff961f70000 - 0x7ff961fa2fff ntmarta.dll 10.0.19041.3636
0x7ff962740000 - 0x7ff96274bfff CRYPTBASE.DLL 10.0.19041.3636 (WARNING: No symbols, cryptbase.pdb, 43558FE9BA9992B8B538FCC4E01A0C251)
0x7ff9627d0000 - 0x7ff9627fdfff Wldp.dll 10.0.19041.4597
0x7ff962b90000 - 0x7ff962bc2fff DEVOBJ.dll 10.0.19041.4355
0x7ff962cb0000 - 0x7ff962cc1fff UMPDC.dll 0.0.0.0
0x7ff962cd0000 - 0x7ff962d1afff powrprof.dll 10.0.19041.3636
0x7ff962d20000 - 0x7ff962d51fff SspiCli.dll 10.0.19041.4239
0x7ff962db0000 - 0x7ff962dd3fff profapi.dll 10.0.19041.4355
0x7ff962ef0000 - 0x7ff962f16fff bcrypt.dll 10.0.19041.3636
0x7ff962f20000 - 0x7ff962f41fff win32u.dll 10.0.19041.4648
0x7ff962f50000 - 0x7ff963066fff gdi32full.dll 10.0.19041.4474
0x7ff963070000 - 0x7ff963365fff KERNELBASE.dll 10.0.19041.4648 (WARNING: No symbols, kernelbase.pdb, FD00366E659CCAC64FA32290CA0C38AA1)
0x7ff963370000 - 0x7ff96346ffff ucrtbase.dll 10.0.19041.3636 (WARNING: No symbols, ucrtbase.pdb, 5C4F64BF99F5FDEC7295CAB05A30010D1)
0x7ff963470000 - 0x7ff9635cdfff CRYPT32.dll 10.0.19041.4597
0x7ff963680000 - 0x7ff96371cfff msvcp_win.dll 10.0.19041.3636
0x7ff963720000 - 0x7ff96376dfff cfgmgr32.dll 10.0.19041.3996
0x7ff963770000 - 0x7ff9637f1fff bcryptPrimitives.dll 10.0.19041.3636 (WARNING: No symbols, bcryptprimitives.pdb, C5929C77617AD1E4CAB41186FA7BE4AC1)
0x7ff963800000 - 0x7ff9638acfff shcore.dll 10.0.19041.4522
0x7ff963940000 - 0x7ff963994fff SHLWAPI.dll 10.0.19041.4355
0x7ff9639a0000 - 0x7ff963a3dfff msvcrt.dll 7.0.19041.3636
0x7ff963aa0000 - 0x7ff963acafff GDI32.dll 10.0.19041.4474
0x7ff963ad0000 - 0x7ff963be3fff MSCTF.dll 10.0.19041.4597
0x7ff963bf0000 - 0x7ff96435bfff SHELL32.dll 10.0.19041.4648
0x7ff964360000 - 0x7ff96438efff IMM32.DLL 10.0.19041.4474
0x7ff964390000 - 0x7ff96442ffff sechost.dll 10.0.19041.4597
0x7ff964430000 - 0x7ff9644d8fff clbcatq.dll 2001.12.10941.16384
0x7ff9644f0000 - 0x7ff9645c9fff COMDLG32.dll 10.0.19041.4355
0x7ff9645d0000 - 0x7ff964922fff combase.dll 10.0.19041.4355
0x7ff964e80000 - 0x7ff964eeafff WS2_32.dll 10.0.19041.3636
0x7ff964ef0000 - 0x7ff964f9ffff ADVAPI32.dll 10.0.19041.4597
0x7ff964fa0000 - 0x7ff96506cfff OLEAUT32.dll 10.0.19041.3636
0x7ff965070000 - 0x7ff96520efff USER32.dll 10.0.19041.4474
0x7ff965210000 - 0x7ff965332fff RPCRT4.dll 10.0.19041.4597
0x7ff965340000 - 0x7ff96546afff ole32.dll 10.0.19041.4355
0x7ff9656b0000 - 0x7ff965770fff KERNEL32.DLL 10.0.19041.4597 (WARNING: No symbols, kernel32.pdb, 396B53214FBEC11DC2AC82E86F6D8DAA1)
0x7ff9657d0000 - 0x7ff9659c7fff ntdll.dll 10.0.19041.4522 (WARNING: No symbols, ntdll.pdb, 4C328D42D0B9A2B218FB85860DECF27C1)
That’s a well-known and long-standing bug that is puzzling Muse and which they don’t seem able to fix:
For me it went away for a while, but then came back - go figure …
Peter
Does the .1 edition fix the issue I talked about whilst it’s recording for 2 straight hours and screensaver comes on it gives a crash log and a loss of my archival recording of Heritage Chart the other day.
That really drove me mad and irate I really don’t want it happening again. I want it recording when norton comes up and sleep mode comes in even if it does the popping sometimes it did before when it did so at least that was normalish behavior and let me record in a PC Screensaver Sleep Mode.
After I update into 3.6.1 release, the progress bar or seek bar looks flashy and irritating. I have upload a short video with no sound, to show you how does the seek bar look like during playback or pause. It happened after I update to 3.6.1 release.
I came straight to the forms after the update… they’re awful all my macros and presets are broken and I haven’t been able to get the same quality in sound back and I’m mid project.
Being able to see the bitrate really important for radio industry folk - some of the playout systems play badly if everything isn’t either 44.1 or 48!
Note that the sample rate in the track never is used for what you export, only the sample rate in the export window itself is. If you need to conform a track, doing so inside the project is an unnecessary step.
The reason I want to see the bitrate for individual tracks is not related to the export rate though.
As I explained in my original post, for some reasons the source files I received for different tracks may not be of the same bitrate, so it’s preferrable to have an easy way (like in previous version) to quickly check the bitrate of each track so that I can convert all the tracks to the same bitrate if necessary, as some of the effects (e.g. noise reduction) cannot be applied to multiple tracks on the fly if they’re not of the same bitrate.
I’m grateful that the software is still being updated, but I wish the things that are removed would be turned into options instead.
I also work with files with different sampling rates, so it was really useful to be able to see it in each track.
