Audacity 3.6.4 cannot process M4A
Quite simply it cannot do so because it cannot find ffmpeg - and neither can the user, according to multiple posts in this forum. I am greatly surprised at this: the issue of not being able to locate ffmpeg in this version of Audacity was first reported some weeks ago and is still not fixed. Why is this ?
Works fine for me on Windows 10 with 3.6.4 and latest alpha test build for 3.7.0
Peter
Can’t quite see how that helps those of us who are not using Windows solve the problem. This is like the traditional response from a help-desk (I know; I used to run a global one, but that was 40 years ago…): ā€œIt’s your problem because it runs OK hereā€, somewhat missing the point.
I was merely pointing out (for the benefit of any Muse QA folk who might be reading here) that is not an issue on Windows - which helps them narrow down their lines of enquiry and investigation.
And BTW I’m a Windows user (no Linux engine and no desire to have one) :wink:
If you ever explore Muse’s GitHub issues log you will see many posts which exclude bugs happening on particular OSs. In fact they even have a Linux flag for Linux-only bugs and a Mac flag too - but not one for windows
Yeah me too, after I retired 17 years ago I worked a a Forum Elf on the old Audacity Forum and later continued when I joined the old Audacity Team - and I still continue a bit now that Muse have taken over the project.
It’s important to know that this Forum is not a ā€œhelp deskā€ in the traditional sense of the word, rather it’s a place where users come to help other users. Muse provide the wherewithal for this Forum but they don’t really provide help-desk facilities,
Sorry if it came across like that, it wasn’t meant to.
Peter.
It ā€œsort ofā€ works for me with Audacity 3.6.4 on Ubuntu 22.04 LTS, though it does produce a warning:
Could not open file /filepath/filename.m4a: Incorrect filetype.
before it imports the file.
Which distro/Linux version are you using?
I’m using Mint 22, based on Ubuntu 24.04 LTS, running the AppImage version of Audacity 3.6.4. The error message says that the file (nnn.m4a) is an Advanced Audio Coding file, which is an incorrect file type (which must impress the developers of the AAC standard, but not a lot) and cannot be opened unless ffmpeg is installed - which a terminal instance tells me it most certainly is. No .m4a file can be opened/imported.
I haven’t tried removing ffmpeg and re-installing it as the removal step will also remove get-iplayer, which I prefer not to do.
Audacity Prefrences, ffmpeg locate function, did tell me it couldn’t find file ā€˜libavformat.so.*’. I was able to browse and point it to a version named ā€˜libavformat.so.60’ but Audacity still couldn’t find ffmpeg.
I can confirm that Audacity fails to load FFmpeg on Mint 22. I’ll log it as a bug.
Also, Audacity 3.6.4 AppImage crashes for me on exit.
Bugs logged:
Th unofficial version from ppa doesnt suffer of this problem. I know, that is not ideal to install from ppas, but Panda Jim make quality work. I haven’t encountered any bugs that the official AppImage version doesn’t have. In fact, it seems to have fewer issues, like the one mentioned here.
