When attempting to load the following message appears, “Audacity cannot be opened because of a problem. Check with the developer to make sure Audacity works with this version of Mac OS X.” etc…
Opening up the error report finds:
Dyld Error Message:
Library not loaded: /usr/lib/libc++.1.dylib
Referenced from: /Volumes/Audacity 2.3.0/Audacity.app/Contents/MacOS/Audacity
Reason: image not found
Hopefully a minor release will come out shortly to fix said issue.
Reverted back to Audacity 2.2.2 which works as expected.
Actually not “under the wire” - with 2.3.0 we have discontinued support for Snow Leopard 10.6
2.2.2 is the last supported version for Snow Leopard, sorry.
