Amplify Preset Amount Shortcut and Select ALL Shortcut?
Hi! I heard about using a key shortcut to use a preset amount with Amplify effect, (example using a key shortcut to Amplify -2), and just tapping twice for -4, etc. Is there a way to set this up? Right now I have a key for amplify but I always have to set the value.
And can “Select ALL” be shortcuttedc to a keystroke? I looked for relevant info, but not finding it yet.
Maybe someone can steer me straight.
Thanks!
First you need to set up a Macro that contains the amplification (personally I would use Normalize rather than Amplify)
In the Macro set the level you want to Normalize to in the parameter settings
See: https://manual.audacityteam.org/man/macros.html
Then create a shortcut for the Macro
See: https://manual.audacityteam.org/man/keyboard_preferences.html
Or you can just keep the Macros Palette open and pick your Macro when you need it.
@waxcylinder Much appreciated! Applying this now.
The shortcut for Select All is Command+A.
– Bill
@billw58 Thx! Short enough shortcut for me.
