Peter,
I updated to 3.0.2 just to be safe. I have included two different screenshots to compare the “Change Speed” versus the “Change Tempo” effect to demonstrate the variance in end result.
Using the example shown above, If I want to shorten the duration of the clip from 48.051 seconds to 48.000 seconds:
The “Change Speed” effect calculates the Percent Change as +0.106%. With 3 full decimal places under Selection Length, the resulting duration is 47.999980 seconds. This allows me to append the clip onto itself over and over again with perfect Zero Crossings at the beginning and end of the clip.
The “Change Tempo” effect calculates the Percent Change as +0.109%. Because the Length (seconds) only allows 2 decimal places, the resulting duration is 47.998 seconds, a full 2 milliseconds shy of the 48.000 second goal. If I adjust the “Change Tempo” Percent Change to +0.106%, just like the “Change Speed” effect, the resulting duration is 48.001, 1 full millisecond over 48.000 seconds in length.
I understand this seems like a small difference, but the project I am working on has multiple segments on one AUP3 file that I have to separate out and manipulate individually. Each clip uses unique instruments at different volumes. It only takes a couple of milliseconds of overlap to create an ear piercing click or pop. Over time the variance compounds and “Cut Lines” get sloppy.
I have enclosed a screenshot of both the “Change Speed” and “Change Tempo” effect on the same clip to highlight the differences. This example has a small variance in the outcome, but some clips I work with are much more extreme. In addition, sometimes I have to adjust the Tempo at an eighth note or smaller. The 3 decimal places used by the Selection Length in the “Change Speed” effect really help because I am using Start and End points at X.125, X.375, X.625, or X.875 seconds.
Thanks for your consideration. It is my hope I have made an adequate case for this programming change. Regardless, I really appreciate the time and effort that the Audacity team have put into the upgrade to 3.0.x. I don’t know how many times I have lost work because I moved or renamed the old AUP file, but not the _data folder that goes with it.
Experienced Audacity 2.x.x user on Windows 10
Newbie Audacity 3.0.2 user on macOS Big Sur 11.2
