3.7 lost "export selected audio" (Mac version)
After installing then latest version, the number one feature I use all the time appears to haven been eliminated. Why is “export selected audio” no longer a choice in the export menu?
I discovered the answer to my own question. Selecting “export” brings up the box where you can change the file name and below that is a choice for the entire project or just the highlighted selection.
I see others have had the same issue. Nobody pointed out the new location of this feature.
@Michael_P
You can still access an Export Selected Audio command - it is not visible by default, so you need to turn on the Extra Menus from the View menu.
You can also create a custom shortcut for this hidden command, you don’t even need to turn on the Extra menus to do that.
Peter
