V3.6.1 Windows 10, 64 bits.
In multi-mode, it no longer shows the zero point. This is useful when cutting out a single wave to remove a click in voiceover.
It also does not show the envelope, although the cursor changes at the envelope point. (This doesn’t bother me; I’m just reporting it.)
When zooming in further, the envelope point suddenly appears, see pic#3.
I couldn’t find any settings to modify these.
Thanks for all your work on Audacity and for any fixes to the above.
The missing zero line is a regression bug that has been fixed for the upcoming 3.6.2 release.
Peter
And I certainly see the envelope both in Mult-tool mode (and Evelope tool mode):
Be aware that there is a known bug (already fixed for 3.6.2) for envelpes on clips that do not start at zero:
Peter
Hi Peter, thanks for the reply. I installed on another Win10 machine and on Ubuntu 24.04 and now see the reason for my envelope confusion: the envelope is at the edges! I always took the inner control point to be the envelope itself and the only way to adjust it as there was a color difference there.
On Mac (not sure about Windows) the zero line re-appears when you zoom in a bit.
