Hello, many thanks to whoever puts in the work to provide the free audacity software.
I downloaded the software (version 2.0.2) in order to be able to create a Medley/Megamix of Michael Jackson songs - from others here who have experience in doing this, is the task relatively easy providing the manuals and tutorials have been thoroughly worked through?
This is what I had hoped to do, yes. I have noticed that there are ‘Fade In’ and ‘Fade Out’ commands while having a quick play with the software, so I assume these will have to be utlised in some way. After having looked at the software so far it looks as though it will take a certain amount of time to master, as with any software interface.
I do have an example of a track to illustrate what kind of megamix I am aiming to create, albeit in a much simpler fashion, as the following link was very professionally produced: http://www.youtube.com/watch?v=MWU4nHo3r8Q
The best way is probably to import each one onto its own stereo track (one above the other)
The use the time-shift tool ↔ to slide the along so the end of the first slightly overlaps the second - try to match the beats. Etc for all other tracks
Then manage the fades - you can do this by selecting the end overlap and using Effect> Cross Fade Out and then select the start overlap and use Effect> Cross Fade In.
Test it by listening - Undo if you want to undo and revert any changes
When you export Audacity will mix & render the tracks into a single stereo track.
Many thanks for your response. I have also noticed there is a ‘Vocal Remover’ effect available, is this easy to master?
I have quickly tried to remove the vocals from a track, but it seems as though the key to this is finding out the frequency at which the vocals reside, will this be difficult to ahieve for some tracks?
Many thanks for your responses, apologies for the late reply.
I had assumed this with regards to the Vocal Remover, I think considering I am a beginner with this kind of software that the other features will suffice.
