Unfortunately in 3.0 a progress pop up appears while Audacity is called with: “PlayLooped:” and makes it impossible to stop with: “Stop:”.
What do we do?
Has anything else been changed in the script-mod-pipe?
I’m getting a bug report: “Something seems to have changed in the in out pipe files from audacity 3.0 (at least on windows), unable to find the pipe now.”
Oh dear, that’s unfortunate.
It also applies to “Play”.
Not a problem for a non-interactive script, but very problematic for an interactive one. I don’t see a way round this. I’ll ask the developer (James) about it.
Probably. I know that some of James’s scripts have broken due to changes, but I’m not sure what. Possibly some differences in how selections work.
As it’s a regression, we also plan to clear it fast.
Our current plans are for 3.0.1 by 17th April (if everything works out!) and fixing some of the top recent bugs. https://bugzilla.audacityteam.org/show_bug.cgi?id=2701 will be amongst them, and should be available from GitHub Actions well before actual release.
