I notice that hes using audacity, but I don’t understand what hes doing to the vocals to achieve his voice effect, can anyone tell me? I’d like to use a similar effect in my own music.
https://www.youtube.com/watch?v=oMzvpJqPIuw
https://soundcloud.com/negativexp/hunter-vibing (Full version of it)
Oh yeah, also im using Ubuntu 21
Trebor
January 28, 2022, 12:46pm
3
Helmet-Radio plugin should work in Audacity on all platforms.
It can be used to create lo-fi microphone effects …
it doesnt really sound quite right, do you think hes doing smth else as well?
Trebor
January 28, 2022, 1:51pm
5
His voice is double-tracked: he sings the same line twice … Stream Hunter Vibing by NEGATIVE XP | Listen online for free on SoundCloud
Also in parts he’s applying reverb … Stream Hunter Vibing by NEGATIVE XP | Listen online for free on SoundCloud
He’s also panning his voice left & right.
There’s also hiss noise, (which is probably intrinsic rather than an effect). You can add hiss via the helmet-radio plugin.
is he singing the lines the same both times or like in a different way? (quieter, lower pitch, farther from mic, etc)
Trebor
January 28, 2022, 2:31pm
7
IMO different ways: one way is closer to speaking than singing. The other way is sung, (& has reverb).
[ PublicAddress plugin is similar to Helmet-radio, but has echo & reverb built-in].
alr ill try this stuff out, thanks for helping
