I am using an audio 8 DJ to record a set from my DJM 800 mixer.
I am trying to record with audiacity, however the only stereo input it offers is channel 1 and 2, I cant use those cause I have a line signal and they are phono inputs.I have to use 5,6 or 7,8. But in audacity these only show up as mono and I cant record them as stereo.
The instructions suggest strongly that Audio 8 DJ uses ASIO drivers. Audacity doesn’t support ASIO. Audacity does support the Windows drivers, but they only support one stereo pair.
I’m not on the mac right now I will check later today. I think all it said was Audio 8 DJ and didn’t allow selection of each channel. I think your first post is correct, its just not a compatible system.
Hello, i have a macbook pro 16inch, i updated my mac to macOS monterey, i have a problem to install the friver of my audio 8 dj from native instruments, please i need heeeeeeeeelp
