New to using Audacity and I know little to nothing about this stuff, so I’ll apologize in advance. I’m trying to convert some OOP vinyl to digital and getting a lot of clicking during the playback of the project. I do NOT here this noise while monitoring, so I don’t understand. This is not the random vinyl clicks or pops but a near-constant noise over the recording.
I did have to fix my MIDI settings (they were at 48 mHz, not 44.1). I changed the buffer to 0 (and did get dropouts), I turned off the wi-fi and disabled napping.
Still getting the constant clicking. Any other thoughts? Appreciate any help
Is the clicking some kind of regular?
Can you see the clicks in your waveform of the recording? (you may post a screenshot or even send a example recording)
Does the clicking occur when you use this recording setup with another source (= not the turntable)?
Just to be sure, I tried a different record and still got the clicking. I haven’t tried using phono out and then using the built-in amplifier to the UFO202
Attached is a screen shot of the wave form and a clip of what I’m hearing (though I do not hear the clicking when monitoring):
