I have windows 10 set to use my D drive for temp space and everything else and have for ages however audacity keeps using the C drive and filling it up (it’s small and also a flash drive which I don’t want written on constantly!). I had audacity installed on my D drive. I tried changing the temp space for audacity because I kept getting space warnings in windows but then it looks for a config file on startup and crashes every time so I just uninstalled it.
Not 100% sure if this is an audacity or windows problem or both, but I would think you should be able to just set the temp location to a new area in audacity successfully either way without ruining the installation. Not 100% sure which version I was using but it was installed last week so probably the latest version.
