Downloaded iZotope Vinyl plug in for Audacity 2.4.2 running on my Windows 10 laptop. When I go to Effects>Add/Remove Plug-Ins, the iZotope files appear as “New”, but after I click to enable them, then click OK, I receive the error message: Effect or Command at C:\Program Files(x86)\Audacity\plug-ins\Steinberg\VstPlugins\iZVinyl.dll failed to register: could not load the library.
I don’t know if any versions of iZotope Vinyl work with Audacity (I use Linux), but the iZotope website says:
System Requirements
Operating Systems:
Mac: macOS 10.13.6 High Sierra – macOS 11 Big Sur
PC: Win 8–Win 10
Plugin Formats:
AAX (64–bit), AU, VST2, VST3
Supported Hosts:
Logic Pro X, Live 9.7–10, Cubase 9.5–10.5, Pro Tools 12–2020, FL Studio 20, Studio One 5, REAPER 6, Reason 11, Bitwig Studio 3, Cakewalk by Bandlab, Digital Performer 10
(Note that Audacity is NOT included in the list of supported host apps.)
