Blue Yeti High Pitch- fixable in post, but can it stream?
Did you buy a new mixer? Do you need advice? Post here.
Excalibvr
Post by Excalibvr » Mon May 25, 2020 9:15 pm
I recently purchased a used Blue Yeti. Every time I have tried to record, I get a high pitched static interference in the background, see attached for example.
Things I have tried without success:
-Plugging it into another computer produces the same high pitch problem
-Brand new mini-b usb cable also produces the same problem
-Running a series of 2 usb hubs away from my computer (i.e., USB port from mobo --> hub --> hub --> microphone), and these hubs did not take any kind of external power. This seemed to have no effect on the whine.
-Turning down the levels in Win10 and turning up the gain on the mic/vice versa
Things that have sort of worked:
I can record stereo audio into Audacity, then choose 'Split Stereo Track.' This seems to isolate the high pitch; i can then mute or delete it and all is good. Image below is an example of what post-production looks like with the noise muted.
All of this is to say, I can fix it in post-production, but can never get it to actually record/stream correctly. Did I just buy a busted unit, or is there any hope for further troubleshooting?
Thanks! :)
Test High Pitch.wav
(622.04 KiB) Downloaded 60 times
Re: Blue Yeti High Pitch- fixable in post, but can it stream?
Post by kozikowski » Mon May 25, 2020 10:18 pm
I've never heard one that bad. That's "Yeti Curse." That's the USB data stream interfering with the USB 5 volt battery system, both in the cable.
Normally, the computer produces 5 volts to run things like your mouse or keyboard. It's supposed to be pure, clean 5 volts DC "Battery", but sometimes they cut corners a little and it's not so pure and clean.
Scene shifts to the microphone where, to cut corners, they run the super sensitive electret microphone element direct from the raw 5 volts coming from the computer instead of cleaning it up first. This is the computer and the microphone pointing at each other: "He's going to clean it up."
Audacity has a pre-baked effect to get rid of that, but I think in your case, the microphone may actually be broken. I've never heard it that bad and it doesn't respond well to the fixes.
Where did you get stereo (two sound tracks) from? The Yeti is a mono microphone. The two tracks are badly damaged like a software interface is broken...???
The original answer is no. If the microphone isn't clean at the git-go, you're stuck. Audacity doesn't do anything in real time.
It wouldn't. The object of that experiment is to power a hub from the wall so the Yeti five volts is coming from clean, stable wall power instead of the ratty computer power. We stopped recommending that when people kept coming up with USB hubs that were so cheap and crappy, you just substituted wall power noise for computer noise.
Can you try it on a Mac? Don't load any interface or driver software. Just plug it in. Let the machine recognize it and see what it sounds like.
I've never encountered an actual broken Yeti, but that doesn't mean there aren't any.
Excalibvr
Post by Excalibvr » Mon May 25, 2020 10:45 pm
I just tried it on a pretty old mac, and it seems to be having the same problems. I can only assume when it is happening on 3 different computers, it has to be the mic?
Don't take me at my word because I'm admittedly way out of my element when it comes to audio issues, but I am using Audacity 2.3.3 and I do have the option to select my recording channel as "1 (Mono) Recording Channel" or "2 (Stereo) Recording Channel" with the Yeti as my recording device (using MME as Audio Host, if it matters). When recording with 2 (Stereo) as the option, I am then able to click on the Dropdown for my waveform and select 'Split Stereo Track.' This gives me two tracks, where one of them seems to have the high pitch 'contained.' Mute that second track and boom, I can export good sounding audio that I recorded from my Yeti.
I realize my picture didn't come through on the first post, I'm trying again below but I've also included a link to a screenshot of what Audacity looks like with the settings referenced above.
http://ibb.co/bdc570q
Excalibvr
Post by Excalibvr » Mon May 25, 2020 11:13 pm
Appreciate the speedy response! I just tried it on an old iMac (OS X 10.9.5) via Quicktime and yes, the high pitch is still there too. Thats 3 different computers now, which makes me lean even further towards the mic being the issue.
I am admittedly out of my element when it comes to audio issues so don't take me for my word, but I am using Audacity 2.3.3 and I do have the option to select my Recording Channel as either "1 (Mono) Recording Channel" or "2 (Stereo) Recording Channel" with the Yeti as the recording device (and MME as Audio Host if it matters). When I have "2 (Stereo)" selected, I can click into the dropdown on my Waveform and select 'Split Stereo Track.' This gives me two tracks, where one of them seems to have the high pitch "contained." Mute that track and boom, I can export good sounding audio that I recorded on my Yeti. I've provided samples of one with the high pitch and another with it removed in the attached.
I notice my picture didn't come through on the last post. Trying again here and attaching it as well. It shows how Audacity looks with the settings referenced above. Image
I'm coming to grips with the fact that it may not be able to be used for streaming, but it seems that it shouldn't work for post-production too if that is the case.
Audacity split track.PNG (36.02 KiB) Viewed 685 times
Test High Pitch fixed.wav
(622.04 KiB) Downloaded 14 times
Test High Pitch.wav
(622.04 KiB) Downloaded 13 times
Post by kozikowski » Tue May 26, 2020 12:56 am
The microphone and recording system should deliver a clean, pure voice which may have a slight tonal imbalance or might be the wrong volume. That's it. Your Yeti, past anything else being broken, starts the day in disaster recovery.
This is from a small, stand-alone sound recorder in a very quiet room. No changes to the recorded file except cut down from a much longer piece.
FurryShortSample.mp3
(255.92 KiB) Downloaded 16 times
Again, it's not unusual for a Yeti (and ones like it) to have this whine problem, but I've never seen one this bad. Did you save your receipts? Good return policy from the store?
Post by kozikowski » Tue May 26, 2020 1:10 am
Did you offend some deity in the last couple of weeks?
Test High Pitch has an almost perfect Left channel except you're too close to the microphone and your Ps are popping. Easy fix.
The Right channel is a disaster.
If somebody paid me to make that happen, I wouldn't know where to start.
Do you have the machine set up to record on-line music or YouTube sound?
What's the possibility you're recording from more than one microphone? Webcam?
Post by kozikowski » Tue May 26, 2020 1:15 am
Maybe I got one.
Screen Shot 2020-05-25 at 18.13.32.png (19.91 KiB) Viewed 684 times
Regard #2. There are three microphones in there for the different patterns and directions. One of them could be fried.
Mess with the pattern selector on the back.
Excalibvr
Post by Excalibvr » Tue May 26, 2020 8:29 pm
Appreciate the help, again Koz!
I am thinking this is the case, as the 'stereo' audio I record always brings the high pitch noise in on the right channel of the track. At least I can bring the good-sounding left side to the middle and have something to export.
I tried each of the different modes on the back (original recordings were in Cardioid mode), but they are all plagued by the same problem. The technology fairy is just not having it! Unfortunately that's the risk you take when buying used from your local FB marketplace, $50 seemed a good deal but I can only assume the seller was aware of these problems when getting rid of it.
I guess I'll need to record an audiobook or something to get use out of this Yeti, instead of streaming with it as originally intended ;)
Post by kozikowski » Tue May 26, 2020 10:46 pm
They go for $150 new-inna box. So you got 2/3 of a Yeti.
Try it. Back way from it a little and do this sound test.
https://www.kozco.com/tech/audacity/Tes ... _Clip.html
Post it exactly as it comes out with one damaged track.
Excalibvr
Post by Excalibvr » Wed May 27, 2020 12:17 am
Here is the sound test:
CatskillFarmRemembers.wav
(1.68 MiB) Downloaded 21 times
