I have installed the Youlean loudness meter. I can’t get it to do much of anything. There is a “preview” button and pressing that will measure 6 seconds of the content I’ve selected in the Audacity window; then it stops and I don’t see any way to get it going again. All the videos I see of the meter show it measuring continuously. When Youlean is open I’m prevented from activating Play in Audacity. If I have something playing in Audacity I’m unable to open Youlean.
I’m using Audacity 32-bit v 3.7.1 and Youlean VST3 version 2.5.10.
Youlean does not show up as an available plugin under Analyze, only under Effects. I wonder if it is installed incorrectly?
It also shows up in realtime effects … Using master effects & realtime effects | Audacity Support
