WTAUTOMIXER w/ Audacity
Hello,
Could you tell me if the WTautomixer will work with audacity? If so, would it work with an earlier version like 3.5.1?
Thank you
SK McDaniel
It probably does NOT work with Audacity (any version), but note that the wtautomixer website says:
We encourage you to test the plug-in with your host application before purchasing
I took a quick look at the user manual online and Audacity is not officially supported.
Note that Audacity is an “audio editor” not a full DAW. Very few commercial plug-ins officially support Audacity but some work. With free plug-ins they usually don’t list the supported hosts so it’s hit-or-miss.
